Quick Question
1 Attachment(s)
Time to fire up the old sewing machine. The motor was always lethargic, so I thought I'd inspect it. It has a diode connecting both brushes on one side, and a capacitor(?) connecting the brushes on the other side. The blue thing is marked 0.02(M) 400, I'm assuming it's a cap. It's from the 1970's, so I'd feel better replacing it.
Can I replace it with a film cap or electrolytic? Cuz it is AC, but there's a diode. |
Good, I finally get to help someone
The diode is to limit any inductive kickback from the motor as it winds down. Effectively, it prevents overvoltage from the motor as it attempts to keep the current going. The capacitor is to smooth any voltage fluctuations present in the circuit. For the circuit to work, the capacitor should be unpolarised and shunted with the diode, across the motor. (A film cap will do) Hope this helps, Zach |
Well... a new cap didn't help much, but the motor does seem a tiny bit more lively. Also I'm back to not being sure about the diode's purpose. I would think the diode would be to prevent inductive kickback... on a DC motor. It's wired so that Line goes through one half of the field coil, through the diode, to one brush, through the armature, out the other brush, through the capacitor, then through the other half of the field.
So it's like....half wave rectifier?? Meh, it works, that's good enough for now. |
LINE -> field -> diode -> commutator -> capacitor -> field -> NUETRAL |
The cap is in series with the windings??? I would have guessed that it would have been accross the brushes to suppress RFI. :scratch2:
jr |
I know, it's freakin' weird. But it works.
