Old 02-02-2017, 12:22 AM
Rca 621TS
I picked up this TV this evening. Drove to Houston, sealed the deal and drove back. Got in about 11pm.
Overall the set looks nice. It is an older s/n like C 0003445. Pretty clean inside and no rust except on the surface of the transformer. Here are a few pics of it:
I tested the 7DP4 picture tube with my BK 467 CRT tester. Here is the result:
And the LIFE TEST:
The HV lead was disconnected and in faint letters the word BAD was written on the top of the CRT:
What gives? The tube looks to be in excellent condition.
Very pleased with the purchase.
But wait, there's more!
I also got this from the same seller:
Old 02-02-2017, 01:45 AM
EdKozk2 EdKozk2 is offline
Tinker
Crist,
Glad you were able to buy the 721 with a good CRT, and that Philco. They will keep you busy for awhile.
Ed
Old 02-02-2017, 08:39 AM
Thanks Ed. They will.
Old 02-02-2017, 08:43 AM
I rechecked the CRT this morning. Yup, it checked that good and no shorts or anything like that. No rattles either. This CRT looks brand new and is a genuine RCA 7DP4 CRT. No evidence of being rebuilt either. I'm not sure those could be rebuilt anyway.
Also the TV does not have a back. So, if anyone has one let me know. I'm going to see if I can find a good picture of a back and see it one can be made without too much difficulty too.
Next up, I'll pull the chassis. Stay tuned.
Old 02-02-2017, 09:48 AM
Yes, they could be rebuilt. Scotty at Hawkeye was doing them before he shutdown a few years ago. Pretty much the same gun as any other early B&W CRT. Only difference being the electrostatic focus.
Old 02-02-2017, 09:54 AM
Bob,
OK, I didn't think they were re-buildable. Good to know. Why I think this tube is not rebuilt is that the neck is straight with no evidence of an extension being fused on.
Old 02-02-2017, 09:58 AM
OK, pulled the chassis. There very minor rust spots on the chassis but no big deal. The bottom line is it looks like somebody did a partial resto on it. I should have noticed the fuse holder as my first clue. This one will be a good one that's for sure. Seeing it has been partially restored, should I take the chance and power it up using a variac?
Old 02-02-2017, 10:27 AM
Well that sure is a nice clean chassis. Apparently the previous restorer didn't have the perseverance and/or resources to complete the project. Some folks very quickly jump to the conclusion that the big bulb must be at fault. At any rate this should be a very educational project.
[edit] Forgot to ask - is there any indication that the electrolytic cans have been restored?
Old 02-02-2017, 10:48 AM
Thanks Kevin.
Looks like the E-Caps have been re-stuffed. I looked closely and I might just power this thing up.
Old 02-02-2017, 10:50 AM
That circle on the base of the CRT with a date code seems to indicate it's a replacement tube, either new or rebuilt, I know they used that style at least as late as 1960.
What are the numbers?
Old 02-02-2017, 10:52 AM
Originally Posted by eric h View Post
that circle on the base of the crt with a date code seems to indicate it's a replacement tube, either new or rebuilt, i know they used that style at least as late as 1960.
3
48
Old 02-02-2017, 12:13 PM
I powered the set up.
First with the low voltage rectifier removed. All the tubes lit up. Then with the low voltage rectifier in but the H output tube plate cap removed. I measured 263 volts! Riders says 265 volts. I received good audio from a local OTA broadcast! Then on goes the H output tube cap connection. No raster. Bummer. Then I remembered the ION trap. Moved it around a little. Nice bright raster!
Hooked up my converter box and now the audio isn't so good on channel 4. But I got a picture! Horizontal sync needs lots of help. I'll bet its a mica cap. All-in-all, this set looks like it'll do good.
Old 02-02-2017, 01:12 PM
It looks like someone eliminated the PM ion trap and used the resistor in its place.
Old 02-02-2017, 01:53 PM
I think he eliminated the electro-magnet, installed a resistor in its place, and installed a permanent magnet ION trap.
Old 02-04-2017, 01:06 PM
I meant it the other way around! Subsituting a PM ion trap for the EM ion trap and using a resistor in its place.
