Old 03-04-2017, 03:40 PM
VA561's Avatar
VA561 VA561 is offline
High Voltage problem
This thread relates to the previous vertical centering thread. A'64 zenith console, chassis 25LC20QS. The hv should be 25K. With the brightness all the way down, I am getting 16K at the crt anode. When I turn the brightness up to a normal viewing level it drops down to 12K. The voltage regulator is a 6BK4 and the h.v. rectifier is a 3AT2. I am not able to check either tube on my tube tester. The hv adjustment on the back of the chassis is turned up as far as it will go. I currently have about a 1/2" gap at the bottom of the screen. When the brightness control is turned up to a certain point, the picture gets out of focus. Advice needed as to what steps need to be taken and in what order. Thanks in advance.
Old 03-04-2017, 04:10 PM
teevee's Avatar
teevee teevee is offline
The oldtimers would recommend checking the cathode current on the 6BK4, there may be provision to do this. I have seen the recommendation of taking the plate connection off of the 6BK4 and (briefly) trying the set to see if the HV comes up. Bias on the regulator tube should be about 15V cathode to grid.
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
A few checks that you can make to eliminate the most common causes of low HV:
Check the horizontal output, damper, and oscillator tubes.
Check the HV rectifier and regulator tubes by substitution.
Verify that you have proper drive to the HO tube grid, proper screen voltage, and proper cathode current.
Check the DC resistance of the flyback HV winding.
Look for leaky caps, deteriorated coils or off-value resistors in the horizontal sweep stages.
Old 03-04-2017, 04:15 PM
Findm-Keepm's Avatar
Followin' the Rules...
.....and check the B+ sources to the Horiz oscillator, and to the fly. So many times it's not a tube, but the power supply to the tube....
The 1K ohm resistor in the cathode circuit of the 6BK4 will allow you to measure the regulator current - Sams has the procedure.
Brian
USN RET (Avionics / Cal)
CET- Consumer Repair and Avionics ('88)
Old 03-04-2017, 05:37 PM
Old 03-04-2017, 06:10 PM
VA561's Avatar
[QUOTE=andy;3179849]Does the HV adjustment have any effect? There are two general causes of low HV. Either the flyback isn't outputting enough voltage (a bad HV rectifier could also cause this), or it's being loaded down by the regulator.
The HV adjustment has little to no effect. A strange thing, I can't get the screen to go black. The picture I posted of a blank screen was with the brightness turned all the way down.
Old 03-04-2017, 06:23 PM
Old 03-04-2017, 06:45 PM
VA561's Avatar
Just ordered n.o.s. 6BK4A-B and 3AT2 tubes. Is it ok to use a 6BK4A-B in place of the 6BK4?
Old 03-04-2017, 06:51 PM
N2IXK's Avatar
Technohippie
Yes, but the 6BK4C is the preferred type, with the best X-ray shielding.
Old 03-05-2017, 02:08 PM
Did you remove the HV rect tube socket and check the resistor in there?
Is it jumpered out, like it was recommended in another thread.
Old 03-06-2017, 09:28 AM
OK this was missed by all. If you turn the brite down on any
set the pix should go black or nearly so. Fix this first as it causes
an abnormal load on the HV. Start with a by the book set-up especially
the G-2's & bright limit. Could be just someone set them too
high to get a brighter pix. If not adjustments move to the
vid amp & blanking tubes. I remember NO scenario where the
HV will cause too much brite........
Normally I would start at the sweep then move on BUT the video
is so far off it could be the root of the problem.
[QUOTE=VA561;3179850]
Old 03-04-2017, 07:24 PM
Also check the 2- I think they are 1.5 meg resistors off the hv adjust pot they should be matched or at least close. I had the same problem and it wound up being a dogbone cap in the IF strip that had carbonized and rendered the 6bk4 tube useless because the heater for the hv reg tube and the crt and the tube where the bad cap was was bleeding in because it was shorted and the 6bk4 would not regulate. Took along time to find this unusual problem.
Old 03-04-2017, 08:43 PM
miniman82's Avatar
First Light: 1952-2011
You have 6BK4 grid issues, probably caused by the bleeder resistors like Timmy said. My Silvertone had a similar issue, the anode got dragged all the way down to 9kv.
Evolution...
Old 03-04-2017, 10:04 PM
VA561's Avatar
Smile
Nick don't you miss it here in Norfolk? You could drop by here and perform surgery on the Zenith!
Old 03-05-2017, 01:53 PM
miniman82's Avatar
I tried to stay Larry, but they wouldn't let me! lol
Check the value of the resistors around the 6BK4 grid, I'm sure you'll find that one of them has drifted out of spec. Could also be the HV pot itself, use your DMM. Once you've replaced the bad parts, you should be able to set HV correctly with the pot.
Evolution...
