Old 06-18-2018, 03:38 AM
Telecolor 3007's Avatar
I love old stuff
2 questions about Diesel in U.S.A.
I have 2 curiosities:
1) In the '70's-'80's there where some Diesel automobiles manufactured in the U.S.A. Did they ever managed to made rebalible engines?;
2) Some one told me that he seen at an gas station the Diesel fuel pumps somehow in the back of the station, while the gas pumps where in the front. Is this the exception or the norm in U.S.A.?
Sailor Moon
Old 06-18-2018, 08:13 AM
maxhifi's Avatar
maxhifi maxhifi is offline
Thumbs down
Diesel cars except Volkswagen and some Mercedes are not so popular due to a variety of reasons, including historically cheap gasoline, higher initial cost, worse performance versus the gasoline version, and fairly strict pollution regulations.
Notwithstanding, the big three US auto companies do sell lots of diesel powered light trucks, which many people use as their primary car. They are extremely popular and reliable, because diesel engines are so good for trucks and especially hauling trailers. Not every gas station sells diesel, but it's very easy to find in areas where trucks are popular.
Diesel fuel is commonly availible at gas stations along side gasoline in areas where people own a lot of trucks. Diesel fuel pumps have a slightly wider spout so won't fit into a gasoline car's fuel filler.
Old 06-18-2018, 09:16 AM
Some GM cars were diesel. They were DOGS. They converted
the 350 CID Chevy engine & it just didnt work. The 350 running
gas was about as good an engine ever built BUT not the
diesel. Pick up trucks I believe all used purpose built diesels &
are fine. I would never get one just because of repair costs.
The bill can look liker a telephone number !
Old 06-18-2018, 09:54 AM
maxhifi's Avatar
If you're regularly hauling a large travel trailer, or a horse trailer, the fuel savings of a diesel truck make economic sense. Diesel car engines have a tough sell though - worse performance and more cost in everything except fuel efficiency, but even that advantage evaporates with the new direct injection gasoline engines. They do tend to work forever though with minimal maintenance. My 1986 Toyota diesel is as reliable as anything I've ever owned. Like all other diesels though it's noisy and it stinks!
And with the whole VW scandal ruining public opinion of diesel engines, I can't see them getting more popular in the short term.
Old 06-18-2018, 10:58 AM
Actually, they were Oldsmobile engines. Same 350 CID displacement.
The Duramax of today is actually an Isusu design.
Old 06-18-2018, 01:30 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
At least some gas-powered cars can accommodate a diesel spout. I've heard of people filling their gas tank with diesel, one car being a late-model Crapolla. The owner was only able to drive a couple of blocks before the stuff got into the engine and wouldn't ignite. Once the diesel had been pumped out and the car was running again it was smoking like it had a bad head gasket.
Old 06-18-2018, 02:47 PM
IIRC all classic cars that used leaded gas had fill spouts that could accommodate a Diesel nozzle...Sandy G posted a hilarious tale about making that mistake way back in the day...Apparently, carborated cars can take a good portion of their tanks being filled with diesel and still begrudgingly manage to run.
Old 06-18-2018, 03:39 PM
maxhifi's Avatar
The other way around is potentially much worse - I had a girlfriend who filled her Dad's Diesel Jetta with gasoline, luckily the car figured it out and shut down before anything got damaged... he was furious at her! It had to be towed to VW, fuel tank drained, engine cleaned out.. I think he paid $400 to have it fixed. I am always careful not to do it with my Toyota, it would be a fast way to ruin the engine!
As for running carbureted cars on diesel.. never did that, but if you want to troubleshoot an exhaust leak on an old car without a catalytic converter, one thing you can do is put a vacuum hose into a cup of engine oil.. it sucks it right into the engine and makes the car smoke like crazy.. drawing attention to the exhaust leak. I think a modern car with sensors and stuff could be damaged by this practice, but it didn't seem to harm my old 69 ford.
Old 06-18-2018, 05:26 PM
Jon A.'s Avatar
If I recall correctly it was a 1976 Cutlass. Gas-powered cars that will actually run with diesel in the tank will smoke like a tire fire. On the flip side, according to something I saw on TV (Mythbusters I think) only a modern vehicle will run reasonably well on hi-po hooch that would be poisonous to drink.
Yes, gasoline's much lower ignition point would likely grenade the engine in short order. Must have knackered the car's computer settings as well. With diesel in a modern gas car one can just disconnect the line under the hood and hook the pump directly to the battery or a charger and pump the diesel out. Got to use a meter for that part to see which two wires go ~12 volts for a couple of seconds when you turn the key on; don't want to hook up to the sending unit and burn it out. Then, re-fill the tank with gas, turn the pump back on and flush the system through. Finally, plug the pump back in, re-connect the line under the hood, hold the gas pedal half way down and crank 'er.
I'd say you're right about the test you described. I reckon the worst thing that could come out of doing that to a classic car is attracting the fire department. Personally I'd rather use some kind of sensor like the gas company does; being around that much smoke would probably be like being near someone who's trying to get high off hemp.
Old 06-19-2018, 10:35 AM
I bought my Diesel Jeep Liberty in 2005. It was equipped with a VM Motori 4 cylinder turbo Diesel. They were only offered two years in the US, 2005 & 2006. It was discontinued for 2007 for sale in the US because of stricter pollution rulings. They continued to build them for other markets.
It was totaled in 2009 in a freak accident on an ice slicked rural road near me.
At the time I signed on to this website, I still had it. I never bothered to change my screen name.
Old 06-19-2018, 10:43 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
I *just* bought a 1984 Mercedes 300D turbodiesel, which is now in San Francisco. Every maintenance record since new, and it's got 387,000 miles on it. Waiting for the carrier to get word to me as to when they're picking it up.
You just can't find them this clean here in the snow and salt of the northeast....
Old 06-18-2018, 10:07 AM
Some stations have diesel hoses on the same pump as the gas (usually in pickup truck country), some have the diesel pumps separated under a different awning (usually in places where big-rig semi-trucks are the main customers since those things are huge and hard to maneuver in a swarm of small cars), others don't carry diesel.
I've also seen places (usually rural) where only one pump is diesel...Some of those places also have a separate pump for kerosene and or heating oil.
Old 06-18-2018, 12:20 PM
compu_85's Avatar
compu_85 compu_85 is offline
Procrastination Expert
<-- recovering diesel head, I've had 6 diesel VWs, from '91 to '12, a Ford 6.0 Powerstroke, and a 91 Mercedes SDL Turbo. The '12 VW TDI is actually being bought back by VW next month
Anyway, yes some stations in the USA do have the diesel pumps in their own island away from the gas pumps. As long as they aren't all high flow rate truck pumps, I preferred this since a gas car wouldn't be blocking the diesel pump while they filled up!
At newer stations all the pumps are generally together.
Regarding the GM 350 diesels, from what I read by 82 they had figured out the issues.... but the problems up to that point, and horrible dealer mechanics had so tarnished the brand that when fuel prices went down in 85 they stopped selling them in 86.
PS: Here's a nice bit of diesel trivia: What's the only automotive engine with no belts and no chains? A: The VW V10 TDI. Everything, including the accessories is gear driven off the back of the motor. The are also 15 fuel pumps on that vehicle. We have one of those too... it's currently parked waiting on replacement camshafts
-J
Old 06-18-2018, 12:45 PM
I love old stuff
I'm curios how relaible would be an 1988 "Cadillac" Diesel.
Sailor Moon
Old 06-18-2018, 03:16 PM
I love old stuff
One day I was in a small "Daewoo" Damas van with somebody (I don't poses a driving licence) and he ask me to put the fuel. I thought it had an Diesel engine, but luckly I asked if I have to put Diesel fuel (motorină)... the vehicle haves an gas engine, not a Diesel one.
Sailor Moon
