Old 02-09-2018, 12:39 PM
decojoe67's Avatar
Originally Posted by maxhifi View Post
You said it, this hobby is definitely not about cost recovery. Looks really nice! Is this one of the ones where you have to give it a push to start the motor?
Thank you. When cost recovery is what comes to mind the most, then you're not a true collector.
The phono has a very simple synchronized motor that "floats" on 3 metal rods that are inserted into flexible rubber hangers. You just put the record on the platter, put your fingers on the center label and give it a sharp spin. It comes right up to perfect speed. They do easily stop when you grab the record to remove it. If these were complicated with idler wheels I likely would not bother with them.
