I’ll put this out-come for a visit and I’ll show you the difference.
I've got a 17" predicta tube (17DAP4 2.68 volt). I checked it with my B&K 466 tester. It pegs the meter on step #6. Just after step #5 where you set the G1 voltage to 45 volts. This is where you gradually increase the pointer by two small divisons, it started to increase 1 divison then pegged the meter. Then when I proceed to step #7 Read Emissions (tests strong) it is like an extra light bulb going off inside the neck of the tube (besides the heater glow). Is this the famous heater to cathode short, for a predicta tube ? What are the chances that a Beltron will repair this tube ? or is it toast. Thanks guys..
Tony |
Last 2 CRTs that tested that way on my 466 when connected to a working chassis arced internally between the HV connector/internal dag and the electron gun (much to the distress of the flyback), did not produce screen light and the entire neck lit up purple. Sorry for the bad news. If your 466 still has its manual I believe it explains the connection between cutoff behavior and gas.
Thanks guys, I was afraid of that. Just needed some confirmation.
Tony |
Paperwork
Does anyone have the paperwork for this tester? I got the tester but no paperwork.
Stlouisian |
Audiokarma |
Have you searched the BAMA (Boat Anchor Manual Archive) for the manual? They have the manuals for most test equipment of that vintage.
Precise 111
BAMA does not have it,
Thread Tools | |
Display Modes | |
