#31
The color bars have an obvious sound beat - so the sound trapping is definitely not right at this fine tuning setting. Does the interference dance to the audio? (hard to tell from a still shot)
#32
Been a while since I have looked at it, but on a guess probably 3/4" or a full 1"? Something like that. This particular mask and frame assembly was from an AXP that got turned into a picture frame, but I don't think they changed anything about its construction in later tubes. Don't remember where I read about it either, but I know that the lip in there is to prevent stray electrons from reaching the screen and lighting up any of the phosphor dots.
Evolution... |
#33
Here's a video of what it looked like back in December of 2015. I guess alignment can go that far off after sitting dormant for 8 months? https://www.youtube.com/watch?v=O15e4R8jr8k
Admiral C322C2 Regent (Restoring) RCA CTC-7 Pensbury (Restored) RCA CTC-5 Westcott (Restored) CRA CTC--4 Director 21 (Restoring) |
#34
alignment does not go off as far as the coils are concerned unless there has been screw driver drift. I would look somewhere else. Clearly the beat pattern is prob from miss tuning of the fine tune adjustment. the other is some kind of interference.
I assume you are using some kind of RF devise for the signal, is that the same as the early example? If RF try a different channel if that is an option. Assuming you have matching transformers and good quality cable for feeding the signal. |
#35
Audiokarma |
#36
#37
Sometimes it is possible for the fine tuning to be so far off that the tuner is recieving while set on the next channel and/or tuned to the wrong sideband of a simple modulator.
If you are using channel 3 on the TV, try channel 4 or vice versa. If your modulator is versatile, try both one channel up and one channel down. |
#38
baluns, terminations, OTA on that channel, connections, etc...
I had one with an intermittent balun in the tuner that gave me issues once. |
#39
Just for the heck of it, try subbing the last IF tube. Ringing/smearing in the luma is a not-uncommon problem caused by the last IF tube, even tho the tube tests 'good' on a tester.
#40
I'll switch to channel 4 and sub the 3rd IF 6AN8. Don't see why 8 months would totally mess this thing up.
Audiokarma |
#41
was nothing done to it in those 8 months?
#42
CTC-4s have PCB IF, sound, and parts of other stages.
#43
changed the channel to 4 and subbed the 3rd IF tube. Not much difference, but now I can get a pretty clear b&w picture, but when I turn on the color all the interference shows up. Once I get rid of all color the interference goes away. The fine tuning knob still has only an eighth of a turn before I lose sync, but about half way through the 1/8 turn clockwise the color starts to fade but does not disappear and the overmodulation hum gets louder.
#44
I must also note that none of the tubes are shielded. I'm sure that isnt helping my interference problem anyways. And Dave, according to the previous owners the set hasn't been powered up since last December.
#45
Audiokarma |
Thread Tools | |
Display Modes | |
