That seems like a very strange location. My rebuilt GE tube has nothing like that, but of course rebuilt means it could have been flashed completely differently from the original.
I have seen it in only one other 21ax and that was the one in Ben Moyer's colorcaster.
Admiral C322C2 Regent (Restoring) RCA CTC-7 Pensbury (Restored) RCA CTC-5 Westcott (Restored) CRA CTC--4 Director 21 (Restoring) |
Found a pix... there are 6 stirrup getters arranged in a circle toward the screen from the convergence pole pieces. There are no getters near the base. Sorry about the poor contrast. Update: found an article with a better pix of the gun assembly. http://www.earlytelevision.org/pdf/R...-Kinescope.pdf jr Last edited by jr_tech; 08-04-2017 at 11:34 PM. Reason: add pix, add link |
Ok here are the official tests on the CRT. The tube tests NOS! This has to be one of the best testing CRTs I've ever seen!
That TV either was not used much by its former owner(s), or else the CRT you tested is a replacement for the original tube. I cannot believe a 50-60 year-old CRT can be in such good condition. The set may have been used by a little old lady who only watched it, at most, once a week or less, and had the original tube replaced in the '60s-'70s.
Audiokarma |
http://videokarma.org/showthread.php?t=257587&page=6 Mine has a date code of 5704, about 8 weeks after your date code. It also tested good and makes a nice picture. My avatar is a picture from that set. I say don't worry about the CRT until you get the set operating well enough to get a raster. Nice save! Dave Last edited by Zenith6S321; 08-05-2017 at 07:52 PM. |
If not, was the neck around the gun area getting really, really hot really fast? |
Seemed like the typical orange glow. Got really hot after about 10 mins. Hope it's not gassy?
That's good. It's under vacuum. (If a jug has gone to air, the heaters won't glow, but the neck gets sizzling hot in half a minute due to conduction.)
Awesome! It should display a beautiful picture then.
Audiokarma |
I do intend to document almost everything I do while I restore this set both cosmetically and electrically. I am doing this to use it a reference and as a step by step series of the restoration of this set due to how rare it is. Next I decided to get the latex paint specks off of the tuning knob. It was a lot harder to remove the paint on the knob than it was on the cabinet due to the risk of harming the fragile plastic. I soaked the affected areas in olive oil to loosen up the paint and then used a pencil eraser to remove as much as I could. As you can see, I wasn't able to get all of it off, but it looks a whole lot better than it did.
You need to variac the chassis real quick to verify the crt has not gone to air, getting super high readings like that makes me question whether it has gas in it. In my experience an AX that has top of the scale readings on all guns is usually gassy, even the tube in MY COLORCASTER (I bought Ben's set) tests like new, but it doesn't tip the scales all the way on all guns like that one does.
If it is indeed good, you have a winner there. But until you've had HV and a picture on it, all bets are off. Remember: a gassy tube that hasn't yet burned out its heaters will show good readings on test, but still glow purple upon HV application. Hence the only quantitive test is to run it on a chassis, if you get something on the screen it's good.
Evolution... |
When I first tested the CRT, it did not test this good at all. All guns tested maybe right above the G on the good scale. It didnt test this good until I let it cook for about 10 minutes at 6.3.
So I put it on the variac and after maybe an hour and a half I was up to 100 volts and the 6CB5 started to red plate in the middle of the plate (No HV either). The set is missing most of its tubes, but I did have in the HV cage tubes, the damper, the H out tube, and the vertical out tube. I forgot to add the horizontal multiplier tube so that may account for the red plating 6CB5 and lack of HV. Current draw was about 2.5 amps and normal current is 3 amps at 117v. I must say I am very weary of applying full line voltage to the set with all the original filters, but I need to see if the Jug is gassy (Which I dont think it is.)by applying some HV to it. Everything else seemed to be normal, no burning smells and the power transformer only got lukewarm after being on for an hour and a half.
Audiokarma |
Thread Tools | |
Display Modes | |
