Old 12-11-2017, 09:27 PM
1911nutjob 1911nutjob is offline
Porta color
Hello guys, first time poster here. My love for tube gear pushed me to buy a porta color that was restored by a pro (I believe it’s a ‘67). I also bought a garage sale find as a parts donor. I’ve read the good and bad things said about these sets here, but this is a practical sized set to collect for my modest sized home.
Can you guys help me out with Sam’s photofacts and sources for spare parts, especially flybacks? I’m also looking for more of these sets for the crazy idea of building a boneyard of sorts. Any and all answers are welcome, even if they’re just to call me nuts.
Old 12-11-2017, 10:18 PM
There was an early and a later porta color chassis that had revisions and thus different schematics. I scanned a photocopy of the early version's Sam's folder for a member here a few years back...I probably still have the file somewhere.
Old 12-12-2017, 09:46 AM
I've never seen a flyback failure on a Porta-Color. I don't think the HV was that high on those sets.
I have two from the later 70's with high focus voltage CRT's and one from 1973 with low focus voltage CRT. The newer sets have a slightly better picture.
Old 12-12-2017, 05:48 PM
I’ve read that about the newer sets, hope to find one someday. These things don’t come up on evilbay too often. There’s a guy on YouTube taking one out of the box NOS. I could never get that lucky!
Old 12-13-2017, 07:22 AM
Never put a FBT in a portacolor either. Keep in mind many GE
FBT's came in 3 separate parts to order. Core halves with spacers
& U bolt, HV winding, and pulse winding.
Old 12-13-2017, 11:09 AM
user181 user181 is offline
The Thordarson FLY-641 is supposed to be an improved replacement for the original. I got mine from Moyer Electronics, to have as a spare.
Old 12-13-2017, 10:44 PM
I just tried searching their website but no dice with that part number. Thanks for the referral, guess I’ll call them instead. Can you steer me towards factory service literature?
Old 12-14-2017, 09:43 AM
Porta color
I don't know of factory service literature -- just the Sams Photofacts. What is the model number or chassis number of your set? That will dictate which Photofact folder you need.
I've compiled a spreadsheet of Porta Color model numbers and their corresponding chassis number and Photofact folder. You can view it here:
https://docs.google.com/spreadsheets/d/1GP8SKSV7EBjYWrVu7AtFUl2oU7p1eyz8LaaJfeEFIYk/edit?usp=docslist_api
I welcome any additions and/or corrections to this document.
Old 12-14-2017, 03:19 PM
Unfortunately the factory labels for this set are long gone. I guessed the year of manufacture based on the cabinet and earlier tube lineup, including the 11sp22 crt.
Old 12-14-2017, 04:47 PM
Have you opened it up? There ought to be some designations inside. At the very least, if you take some photos (external and/or internal), somebody could help identify it.
Old 12-14-2017, 09:29 PM
I had to replace the flyback in my later model (mid-70's) Portacolor. I used a Thordarson from Moyers.
Old 12-15-2017, 12:42 AM
I had it open when it first arrived to attach the power cord, don’t remember seeing any notable labels other than the CRT. I could check again. If it helps at all, the uhf tuner does not have the click stops. I’d gladly post pics but I don’t know what to do since the photobucket fiasco.
The tube lineup is 2gk5, 4lj8, 8ar11, 6lt8, 8bu11, 8bq11, 12jf5, 17bw3, 6ac10, 11fy7, 1ad2, 11bt11, and 12bf11.
Old 12-15-2017, 08:31 AM
Tom9589 Tom9589 is offline
Based on the tube lineup, your set is not the H1 chassis, the earliest model. I had the H1 chassis and it had different HO and damper tubes (12GE5 and 12AX3).
My set developed a heater-to-cathode short in one of the CRT guns. Since there was already an isolation transmission transformer in the CRT filament circuit, I simply removed the 220K resistor tying the CRT filament to +145V.
Later on, I came across the later version CRT (11WP22) and replaced the 11SP22. The improvement was quite noticeable due to the smaller dot size of the 11WP22.
Old 12-15-2017, 11:06 AM
I may add the tube lineups to my spreadsheet for each chassis, if anyone thinks it's worthwhile.
Old 12-15-2017, 12:08 PM
Flickr is a good alternative....I was lucky: My bucket filled a few months before the ransom fiasco, and I said "screw it, I'm not paying them for more space", and went to flickr (thus I did not need to search for an alternative hosting site when the sud hit the fan).
