Thread Tools | Display Modes |
When going through paperwork I found that exact book. I will have to look at it.
My RCA set does not fade to dark. Unfortunately it is always dark. One time on powerup the flyback sounded somewhat close and for just a second the set showed raster. But only for a second until the frequency changed. Sometime maybe today I am going to pull all 4 B&K analysts out and see if any have life. Hopefully out of the 4 at least one will behave. Now excuse my lack of knowledge but what is the "fade"? I don't think I've heard that term. Is it a term with solid state sets as well? I repair a ton of those but haven't heard that term yet. Oh speaking of solid state, does the B&K also have a use with solid state sets? |
Later B&Ks (IIRC the 1077) were designed to work with SS TVs too. Unit 1 probably is good enough to try with the RCA assuming it does not fill vertically (if horizontal is small that could be a problem)...Also it may be designed not to fill vertically...IIRC the slide image is shorter than the CRT...The CRT only needs to scan a pinch below and above the top of the image on the slide but does not need to scan to the top of the slide its self...If it did the image would have big white bars above and below it when displayed on a TV which is not what anyone wants.
There were several models of the Television Analyst produced over the years.
I have a 1075 which is all tube technology, later ones contained more and more solid state circuits and were more capable of being used on solid state TVs. They also added more functions as time went by. I think the oldest was model 1000 and the last was 1077B. Here is a article on the "Phil's Old Radios" website. https://www.antiqueradio.org/BK1077B...ionAnalyst.htm Also here is a link to a discussion on the "Antique Radio Forum" that is also linked to in the Phil's article. http://www.antiqueradios.com/forums/...678&highlight= You have to remember that old test equipment is made of the same things old radios and TVs are made of, the same power up caution is recommended. |
Thread Tools | |
Display Modes | |
