Old 09-26-2018, 07:53 PM
Actually there's quite a few with a single magnet on the side that have two sets of bars extending to clamp around the neck. If I'm not mistaken those would qualify as a double field. I'll see if I can find textbook examples of the two types. Can you see the type number on the neck of the CRT in your TV?
Looking through the pictures, it looks like a 12UP4 metal cone CRT.
Old 09-27-2018, 12:47 AM
I can't tell. All the pictures seem to be from the front and the green Zenith mask is covering the edges of the CRT.
Old 09-27-2018, 10:02 AM
Every 12" Zenith I've seen used a metal cone CRT! The 10" model used a 10BP4 glass tube.
It's been probably 50 years since I worked on one of those.
The Sams would probably show the top view of the chassis and the CRT.
Old 09-27-2018, 12:06 PM
My model 2350RZ1 tube chart lists both 12UP4 and 12LP4. As found with an RCA 12LP4A. I'd expect many 12UP4 were converted to all glass at a later time.
https://c2.staticflickr.com/2/1925/3...78f638c1_b.jpg
Old 09-27-2018, 04:40 PM
Zsuttle's Avatar
Zsuttle Zsuttle is offline
Yeah, this model has the 12UP4, though there's no number on the original ion trap. Though I know it wasn't the original to the set because it didn't match the pictures from the service manual
"If it isn't broke, you aren't trying hard enough"
