Now , to get down to the troubleshooting , we need to talk about troubleshooting itself and what it means to diagnose and repair vacuum tube circuit electrical failures . The "Shotgun" method of replacing parts on a vague "It could be this part" notion is not the right way to go . A LOT of perfectly good parts end up replaced that way at great cost till the bad part is finally changed by the luck of the draw . Yes indeed changing out the failure prone electrolytics was a good action , but now that you've had the episode of reverse polarity and have no sound the best course would be to start over completely . Were this my situation to rectify I'd start by replacing the filter capacitors again because as Electronic M and I have said , they very well could be damaged . Consider mounting a terminal strip to the chassis and attaching the new caps to it as in my picture . I'd put the Selenium rectifier back in the circuit (polarized correctly or you'll REALLY learn what it means to "let the magic smoke out"* !!!!!) and then with a DC voltmeter on a scale of 300 volts or higher , and the schematic diagram , see exactly where B+ voltage actually is and isn't . This of course presumes that the tubes ARE lit and you have no sound . If the tubes aren't lit , start with an AC voltmeter on at least 200 volts scale and using your schematic follow the tube's heater AC path till the open is found . A multimeter , a schematic , and about 5 minutes are all it should take you to diagnose this , once you replace the filter caps and put the rest of the circuit back to original status . Once you've got it running if you want to eliminate the Selenium rectifier , fine , but DO install the proper dropping resistor for the excess voltage of the silicon diode , circuits have "as designed" operating voltages for a reason , and especially in electronics "somewhat higher" is just about never equated with "better" . * If you don't already know , an overloaded or shorted Selenium rectifier lets out a noxious smoke that smells like a bucket of rotten eggs X 10 , so make damn sure you polarize the Selenium rectifier correctly , and also using your ohm meter mode of your multimeter make sure that the new caps you install are wired correctly and aren't presenting any kind of short circuit to the rectifier BEFORE you power it on again ..... Last edited by init4fun; 10-03-2018 at 10:50 AM. Reason: Clarify a point |
Oh , and , Thanks to the schematic graciously provided by Jim , I can see that there is a resistor between the rectifier and the first filter cap . That resistor , R32 , which is a 22 ohm 1 watt , is very likely what made the smoke . I'd still change the caps , and then check R32 as you may well find it open (infinite ohms) . That is also the resistor you'd want to increase the resistance of if you do try again to install a silicon diode .
I had to take mine apart today. It's a 7X03 chassis with OEM part code dates from late 1955. The under chassis view from the OP shows the band selector switch is mounted on an angle with some form of a universal joint, which I thought was rather novel. Mine is mounted straight. I unsoldered all the leads going to the back to make it a little easier to work on. Of course I made a drawing where each one went. |
No the tubes aren't glowing, what I thought was tubes glowing was actually the neon pilot lamp glowing. As for the capacitors I ordered some new ones, and as for the selenium rectifier smell goes, I'm well aware what they smell like, that's why I wanted to eliminate it from the circuit so that it didn't have a chance to fail on me, and I did order a 47 ohm 2 watt resistor to install after the 1N4007 diode. And I did use a terminal strip to install the electrolytic caps. Last edited by vortalexfan; 10-03-2018 at 06:38 PM. |
Audiokarma |
I would start by testing the tubes... the heaters are in series, so if one heater is open, none will light up.
jr |
But they still don't glow. |
If the tubes are good, then I would use an ohm meter to trace around the heater string from one ac input to the other end of the string, following the path shown in the schematic. Could be a bad power switch, a broken wire, bad tube socket, dirty heater pins on a tube or whatever that is causing the open circuit.
This test can be done with the radio out of the cabinet and, of course unplugged. jr |
The heater string is shown toward the bottom of the schematic.
Audiokarma |
Thread Tools | |
Display Modes | |
