May want to scope the sync separator...if it is letting video or noise through that could be freaking out the sweep.
20190220_153323[1].jpg I've also purchased a TV analyst for troubleshooting, seems like a useful tool. WOn't be here for another week
"If it isn't broke, you aren't trying hard enough" Last edited by Zsuttle; 02-20-2019 at 03:03 PM. Reason: Partial fix on issue. |
ETF has the riders which has the waveforms in it on page 30. It's interesting to see that there's a 60hz signal on the sync output, that might explain the jittering. How much of a waveform should I realistically be getting on the power supply? I would have thought that the filter caps being as big as they are would have taken care of it.
"If it isn't broke, you aren't trying hard enough" |
*Granted color changed it to 59.9Hz, but rounding is a thing.
Audiokarma |
Thread Tools | |
Display Modes | |
