Re: Disposable society
Best, Wigwam |
Ah, wimmin.........ya can't live with them, and ya can't kill them.
Too bad someone didn't clue in Scott Peterson. Anthony |
Wigwam, it's not everyday I see a photo of downtown Kenly on the internet!
Re: Re: Disposable society
You could go to one of the above listed sites and hope to give that Westy a good home. I'd hate like hell to see it get thrown in the trash |
Re: Re: Re: Disposable society
As to tossing it out - well there seem to be a lot of stoves like this one sitting by the side of the road around here - but not usually in any kind of working shape, let alone looking as nice as this one does. I reckon we'll try to sell it - not sure where to start, though. Not even sure this monster will fit through our front door - that may be why it's still here! You know anybody who collects and fancies a trip to NC to pick it up, I'm sure we can reach a reasonable price! Best, Wiggy |
Audiokarma |
You know why I wuz in Kenly! - I hadda take I70 to Raleigh to avoid the crush on 40 at Knightsdale - Saturday mornings are obscene! Best, Wiggy in Wilson |
Re: Re: Re: Re: Disposable society
Anthony |
Here's to better luck at the thrifts, and fewer Yankees clogging up the roads!! |
Sweet TV--Steve!!
That a real cool roundie!!! Love to have it. Eric
“Freon” is a trade name used by DuPont for their fluorocarbon refrigerants. It does not identify any particular refrigerant (i.e. R-12 or R-22). As far as performance is concerned, don’t blame the refrigerant, blame the cheap junk it is put in. I’ve been in the HVAC/R industry for some time, and there are many excellent, energy efficient units on the market. Unfortunately, the “Crap-Ola” brand has gotten a stranglehold on the market. Auto A/C units are the same, too. For the most part, just cheap junk. Converting an auto from R-12 to R-134a requires a compressor that will flow 15% more CFH than the original, not to mention the need for a larger condenser, and readjusting the low pressure control.
That being said….Congrats on your find! |
Audiokarma |
Color me guilty of using "Freon" to describe good ol R12, but I meant it in the colloquial sense as opposed to any of the replacement elixirs........most none of which (as you pointed out) are direct drop in replacements and will more often than not result in reduced performance. Unless of course you elect to use Propane (and you know what I'm yakking about!)
Seeing as how you're much more familiar with this than I, am going to install a 1990 Chevy engine with that small radial compressor into a late 50's car and wish to use the original factory installed underdash evaporator, do you feel this is compatible? Of course I'll have custom hoses made up with the proper fittings on either end. AFAIK this compressor was originally an R12 flavor.....should I consider changing to say a Sanden and using R134 instead? Thanks Anthony |
i have a 96 geo tracker made by suzuki. the a/c will freeze you solid. the dash above the vents will get dripping wet with water. my 03 thaoe will throw snow balls at you also.
A Geo with A/C? I bet when you turn it on the extra load on the engine makes it feel like someone just threw an anchor out the window LOL!
Anthony |
Had a friend once with a 4 door GEO with automatic, air, and a 3 cylinder! The whole family would pile into that poor little thing...I think it took 1 1/2 cylinders to run the a/c! One day I was over there watching tv and I heard this noise like an electric motor-they couldn't get it started so they hooked it up to a battery charger and just kept the key turned, I mean they cranked it for for 5 minutes at a time! Finally decided they needed a new motor so they scrapped the car. They didn't want to have to pay someone to change it, how hard could it be to change one of those rascals?!
Bryan |
Hmm that doesn't sound right...if the motor still cranked over it was probably ok...they should have checked fuel pump, vacuum leaks, carbonized spark plugs, coil, distributor rotor, carburetor accelerator pump (if used), carburetor needle valve sticking open causing flooding, fuel lines, etc. If the starter motor just whirred then the solenoid was probably bad. Have had and fixed all these problems on vehicles, when the trouble symptoms were that it would not start at all. I'm curious as to how they arrived to the conculsion that it needed a new motor.
Audiokarma |
