Old 01-18-2013, 05:26 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
I'd forgotten about that trait-I have a pile of CTC-53's but only one inside and cleaned up. It holds my record, by a quite a bit, for longest warmup. I think I timed it at over 60 seconds to get a raster. I do find the picture they make to a have a pleasant quality. Biggest problem with my "good one" is something heat sensitive in the vert circuit that causes a lot of drift until it's good and warmed up. I've replaced the tubes and caps, not sure if I started replacing resistors or not. That set hasn't been turned on in probably 3 years
Happen to have any parts sets? I could use a brightness pot for mine....someone at some point installed a pot with a different shaft, probably replacing one that was defective.
Old 01-18-2013, 11:54 AM
I found resistors on the vertical board that changed value really bad.
My CTC51K wouldn't stop rolling and the size and linearity wouldn't adjust properly. Even when I replaced the 13GF7 and the 50MFD 'lytic.
My set is a real cheapie. It never came equipped with a degaussing coil.
Old 01-18-2013, 12:09 PM
Kamakiri's Avatar
As long as we're discussing this chassis, what the heck is this lever thing? Is this how horizontal centering is accomplished, or is it something else? I haven't touched it, but it seems like it would rotate in the opposite direction if it was....
Old 01-18-2013, 12:32 PM
prob loosen the yoke
Old 01-18-2013, 12:46 PM
It's a long screw for the yoke clamp. Actually for the whole yoke and convergence assembly.
Old 01-18-2013, 01:01 PM
Kamakiri's Avatar
Makes sense, thanks. I was hoping deep down that it *was* some type of horizontal centering adjustment, as I can't get the set to fill out about an inch on the right side of the screen.
Linearity was a little out of whack, but it pulled in fine with a little tweaking.....sounds like I may be looking at new resistors there as well, but damned if I can figure out how to adjust the horizontal centering.
Old 01-18-2013, 03:32 PM
It's been ages, since I did TV repair on a regular basis. Trying to remember if there is a horizontal centering option on that chassis.
Are you sure the damper tube and horizontal output tube is perfect? When you see an image on the screen, such as text, does it seem centered?
If so, your problem is insuffient sweep. Is your B+ Around 255 volts?
BTW, is that the CTC53 or the CTC36, as you seem to be working on two sets.
Old 01-18-2013, 09:36 PM
Kamakiri's Avatar
This is the CTC53. I'm sorry, I really should have broken this into two threads. The sets seemed so close in appearance I had no idea until I got the back off that these were two significantly different animals.
Everything seems centered, but it's so damned close to the edge right now I can't tell if it's a sweep issue or a centering issue. I didn't check B+, because I figured there *had* to be a simple adjustment for this. Ain't seeming like it . And my tester won't do these particular tubes....again, figuring it was an adjustment.
Pretty sure that something somewhere has drifted in value, because after a couple hours of play, it seems to have just about centered itself somehow. I'm not going to ask HOW, but now there's maybe 5/16" of blank real estate on the right side, and that I can live with for now.
I decided that I'm going to go ahead and replace the resistors on the board of the CTC36, I just have to determine the rating of them. Since I don't have the sams for it, I may wait until I get one, I'll probably order over the weekend. I would assume that 1 watt would do, but I don't want to get any surprises down the road.
Old 01-18-2013, 01:38 PM
lnx64's Avatar
lnx64 lnx64 is offline
Yea my TV has the same yoke clamp.
http://img.photobucket.com/albums/v3...n/tvboard3.jpg
Old 01-18-2013, 06:00 PM
Old 01-18-2013, 06:36 PM
I seem to recall reading somewhere that defects in the dual diodes in the horz AFC circuit can sometimes cause odd shifts in the horz centering.
Old 01-18-2013, 09:44 PM
old_coot88 old_coot88 is online now
It can also cause very weak H sync.
Old 01-18-2013, 09:45 PM
Kamakiri's Avatar
I have several CTC53s, and they all had a number of out of tolerance resistors on the horizontal and vertical osc board. Replacing them helped solve a lot of deflection/sync problems. I also found that several of the orange/brown/green drops were out of tolerance, or leaky.
That's no surprise. I kind of figure that if I want these two to be perfect, all new mylars would be the ticket, and resistor checks as well. At this point, though, it's an example of the law of diminishing returns.....the sets are both very watchable, and stable as they are. I've run each for several hours, and they're both now pretty solid performers, each having something slightly out of whack that doesn't really bother me.
I'll probably let these be for now and just run them (unless something fails), as I have a CTC-25A console that I absolutely LOVE that is going to need attention next. I have the sams for that one on the way now. I'm not looking forward to that one, as it's going to need cataract surgery as well. But I absolutely love the set, so it'll be worth it
There's only 4 sets in my humble collection that don't work at the moment. I'm starting to get scared that I'll be left with nothing to do pretty soon!
Old 01-18-2013, 09:14 PM
You need Sams 1342-2. I'm sure somebody on here could set you up with a copy (I have one but not a spare, and I'm trying to keep one full set). The part number for that brightness pot is 126307. It has to come from the CTC53XM chassis; I'll have to check what I have.
Old 01-18-2013, 09:15 PM
lnx64's Avatar
I think my local library has some SAMS there. I could perhaps see if I can photo copy the book if it's not too many pages.
