I tried playing around with the mode switch and it still won't stay on. I'll play with it a little while longer before I give up on it. If the owner gives it to me, I'll have fun destroying it. Actually, a friend has a 13" Funai TV/VCR combo that he thinks needs a new remote sensor; so, I'll make sure to save the one out of this set before destroying it.
http://www.youtube.com/user/radiotvphononut |
I've tried everything, without luck. I'm waiting for the moment when the owner gives me permission to junk hunk of garbage and then I'll have to come up with a fitting way to "end of the line" it! I can honestly say that these are my most hated TV out of any that I've worked on!
^ Oh man, I hope to see a video of this.
If you know any one with one of those gigantic catapults that goes to those pumpkin throwing competitions then convincing them to use it to throw that set half a mile might be a fun way to end it.
Audiokarma |
Trebouchet !!! (grin)
Benevolent Despot |
I hate those machines. Back when I was willing to work on these, I usually would clean the mode switch, and if there was anything still wrong I would just use zip ties to lock the mechanism in the stop-eject position and hope the TV would still work. And those end sensors are a royal PITA!! I have had to work on the machines almost in the dark to keep stray light from tripping the sensors.
On those later ones that the deck ribbon cable was soldered to the main board, I could still separate the board from the deck enough to slip in a new take-up clutch and mode switch. The earlier ones with the sensor LED that would fail, man I must have fixed hundreds of those. And the bad clutches that would leave tape hanging out upon eject. Good stuff!
The TV section seemed pretty reliable though. I recall a lot came in with the picture vertically stretched and had to use a modified remote to access the adjustments. Last edited by Ed in Tx; 06-13-2013 at 09:32 AM. |
Audiokarma |
Just remembered! The LED down under the prism opens and shuts the set down also. Remove the prism and use a cell phone camera to look at the LED. It can see the infrared. If the diode is dim or out, use one from an old remote.
Cell phone cameras work to test remotes also! If all the info here now doesn't repair it, tell it "If you don't work on the bench, work on the floor! Pitch it to the floor!! |
Magnapop!
Best junk TV destruction video I have see thus far:
http://www.youtube.com/watch?v=Vv7MMkrTJOw Saw it in the related videos section while checking out a Magnavox Touch-Tune TV video. The action starts at 0:29. Last edited by Jon A.; 06-15-2013 at 03:04 AM. |
Well, it's now mine. I'm going to salvage any parts off the chassis that I may have a need for down the road and the rest will meet it's end.
Check out this video, along with other creative videos, where he EOL's BPC TV's.
http://www.youtube.com/watch?v=C8B8K9kE5Q0 It's unfortunate that perfectly working TV's have to meet this fate; but, I was talking to him once about this and he told me that in LA, NOBODY wants CRT TV's and that on any given day, he can take a 20 minute drive and come home with several CRT TV's; so, might as well have some fun with them. He found it hard to believe that I was able to sell any CRT TV in my part of the country; but, I now think the "LA effect" has made it's way to the deep south. Currently, I have a 2003 19" Orion that someone gave me and I repaired it by replacing the main filter cap (out of a junk chassis, of course) and rejuvenating it's weak CRT (it was still watchable; but, I wanted it to look it's best). I've been trying to sell it with zero interest; so, if it doesn't go away pretty quick, I may be having some fun with it (along with the '93 RCA console and two 13" TV's that no one seems to want). Today, my criteria for fixing used BPC/SPC TV's is that the TV has to be free and it has to be something that I can fix in 20 minutes, or less, out of my junk stash. The only ones I might spend a little money on are Sony's and TV's with built-in DTV tuners. Concerning EOL, I have a 19" Funai/Emerson LCD with a broken panel that I'm going to destroy and post the video to youtube. I haven't got all the small details worked out yet; but, it should be interesting. Since I have a lot of neighbors close to me, I'm sort of limited on how creative I can get without getting too much attention.
Audiokarma |
