There was very little of the nylon disc left even before I removed the socket. When I first took out the chassis and blew out all the dust, bits of that socket went with it.
The Philcos seem more rare than others. Zenith 19" B&W sets are much more common. I wonder if these 19" Philcos, when they were all around 10-20 years old broke down because of weird problems like bad tube sockets and controls and nobody wanted to put in the effort to fix them and junked most of them. Here's an ad showing the different early 19" Philco B&W models. I've been looking for one of those Town and Countrys for years. Those 19" sets in what look like Seventeener III cabinets with rectangular 19" CRT masks are cool looking too. It also says they made some of these Townhouses with a remote control.
The quality goes in, before the cat goes on!! Last edited by Adam; 10-14-2018 at 08:31 PM. |
I told them, " Stay away from the Philco, they don't stand up worth a damn". The Zenith is a better buy. |
Thanks for looking! At least that resistor I have in there works ok for now.
If it weren't for that ad I posted, I wouldn't have known how much of this cabinet was originally painted silver. I've been experimenting with using Q-tips as small paint brushes to repaint those silver lines on the sides of the screen. It kind of works. If anyone has any suggestions as to how to redo the "Philco Townhouse" script under the channel number indicator let me know? At first, I noticed it was slightly lower than the rest of the cabinet. So I painted the whole area, then attempted to scrape off / sand off the paint around it, assuming the paint in the lower spots would stay put if I just sanded over the whole thing. But the depressions where the letters were were so slight that just a little sanding with 600 paper managed to make parts of the letters level with the rest of it. So if I tried that technique again it would just come out worse. Unfortunately, this cabinet is messed-up in several ways and there is no way I'll be done with it before I have to move to WI next week. I hate moving projects that are underway. I always loose parts.
A pad lock maker used to use a thick near dry paste paint to fill sunken dial numbers*. Perhaps you could use a similar approach. I think your better off applying paint 'wet/uncured' and removing it wet.
*IIRC some of my peers at MSOE had a college senior design project to come up with a less antiquated method. I don't know how small it is, but perhaps a fine tipped paint pen or artists brush and a steady hand could fill the letters.
Audiokarma |
We used the Testors paint pens - get both the red/white/black and gold/silver/black kits and 99% of your needs are met. Paint the area, and go back over with either some micromesh to remove the surface paint, or a MrClean Magic eraser, with light passes. The magic eraser is fine enough and firm enough to not dig out the recesses or mar the surface.
I dunno what grit our micromesh kit is - nothing is marked. http://www.advantagehobby.com/246235...ite/?pcat=1028 Link provided only as a reference - Amazon is probably cheaper.
Brian USN RET (Avionics / Cal) CET- Consumer Repair and Avionics ('88) "Capacitor Cosmetologist since '79" When fuses go to work, they quit! |
I always liked Philco's wacky early 60's designs. Was this branded as a "Cool Chassis" set?
I have a 1962 Deluxe 23 "Cool Chassis" consolette that I rescued from the loft of the theater department Prop barn at Hiram College back in 2009. It's a hot chassis set that worked great as found and hasn't needed work since. It was a dorm lounge TV in it's previous life.
This device isn't a spaceship, it's a time machine. It goes backwards, and forwards... it takes us to a place where we ache to go again. |
I did my first post in the Introductions forum a few days ago, lamenting the fact that all the cool old TVs are from the US and I'm in Europe where everything pretty much sucks. I've been looking online and in thrift shops for months and just finding icky 80s solid-state stuff.
But thanks to this thread, I happened to Google "Philco Townhouse" because I thought that pic looked like one of the ugliest TVs I've ever seen - in a good way, I mean, like lots of those midcentury Philcos. And what was the VERY FIRST thing that popped up on an image search? A freaking Philco Townhouse. In Spain. For 30€. That looks to be in pretty good shape, physically. And further thanks to that listing I have figured out what I need to be be searching for and discovered several other sets from the same era -Zeniths, Sylvanias, another Philco - that were either imported and converted, or made for export. Odd considering that in those days there was only one channel and it was the propaganda channel run by the dictatorship so I have to wonder why they were importing expensive American TVs. But regardless, good news! |
It may have been the only thing on, but there was one Spaniard who was damn determined to watch it in style.
Audiokarma |
