Old 02-14-2018, 11:52 PM
LADR's Avatar
LADR LADR is offline
Местное и дх радио
1961 zenith 16H32 “the barrett”
Saw this set for sale on fäcëböök and I thought it was cool so I decided to get it. After a 4 hour round trip, i got it home and plugged it in and no picture, sound or HV. I checked the fuse and it was cremated so i put and new one in and this time the 3DG4 rectifier starts throwing purple sparks and blew the fuse. I took the chassis out to check the filters for shorts and no shorts were found so I thought it was the rectifier tube shorting when the HV starts so I ordered a NOS 3DG4. The new tube arrives and i put it in the set but this time the HV starts up and i can hear the vertical running, and then a raster! I put the chassis back in to the cabinet and reattached the tuner and was surprised with strong snow and loud sound. I hook up the converter box and there was a nice picture but the horizontal won’t stop rolling. I asked around as to why it’s doing this and someone told me the phase detector diode was causing this so a fellow collector sent me an exact replacement and as the replacement was on its way, i tested all the tubes in the horizontal circuit and all was good except for the 6HS8. The 6HS8 tested very weak so I ordered one and its still on its way. I have decided not to replace the diode until i see what a new 6HS8 will do. I’ll update the horizontal problem when the tube gets here.
File Type: jpg 4F6454ED-8395-4827-9113-3BB1F784CC2B.jpg (65.5 KB, 196 views)
File Type: jpg 4216A291-D5DE-4DFF-887B-40A303A89DF6.jpg (61.9 KB, 215 views)
File Type: jpg 1A5E1AD6-6F12-434E-A960-3557E7D4418A.jpg (51.2 KB, 226 views)
Your good times will bring me down
