Old 06-26-2022, 09:33 PM
YamahaFreak's Avatar
<-- CSXT 6038, EMD GP40-2
UPDATE: When the Digital Adapter was replaced with a regular cable box, it killed the stereo audio. This is definitely a problem with these boxes.
Sony Trinitron Fan
Old 07-04-2022, 11:21 AM
I do not have stereo sound on my service, but Spectrum does not consider the service as cable; in fact, several representatives I have spoken to have informed me I do not have cable, since the service does not use a box, yet it offers almost every channel their standard cable service does. Spectrum calls this "streaming" service, which suits me to a T in more ways than one; for example, I am paying much less for this service than I formerly paid when I had standard cable with a box. I live on a fixed income, so this is very important to me.
Stereo sound on cable TV, stereo FM, stereo records and stereo tape is all but lost to me, as I am practically deaf in one ear (caused by a brain injury at birth which affected the entire right side of my body). That is, I have some hearing in my right ear, but the brain injury I mentioned messed it up so badly I might as well be totally deaf in that ear. Because of this, I have absolutely no use for stereo sound on my TV service or even on my Aiwa stereo audio system.
BTW: However, if you are having issues with stereo sound on your cable hookup, I would inform the cable operator of this since, if you are paying for stereo sound on your cable, you should be getting it. It doesn't seem right to me, either, that you lost stereo sound when the cable box was replaced. The box you had, after all, was giving you stereo sound, so there is no reason (that I know of, anyway) why the box the cable operator replaced it with should not provide stereo audio as well, unless the replacement is an older box with standard (monophonic) audio outputs. Why was your original cable box replaced in the first place if your cable service was working normally, except for the stereo audio issue?
Old 03-17-2022, 10:40 AM
IIRC:
If it was an analog cable system in which the stereo signal was modulated in stereo or simply translated in frequency at the head end, then stereo could get through to the RF input of a stereo analog TV. But if the audio was some how decoded and remodulated from baseband in the cable box, it typically was mono even if the original source was stereo.
