JVC 56P575 no power
JVC 56" rear projection 1080i set plugged in and nothing happening when i push power or attempt to use remote. Can someone point me in the right direction for repair? Not sure if its caps or what. Fuses seem ok.
You get no "click" or attempt at power on?
JVC sets were mainly known for losing the convergence amps...not too much more in my experience. This can shut down the set. but you WILL get an attempt at power on. |
Not hearing anything at all. Just a quick spark at plug in.
Sounds like you don't have your +5V standby supply. This supply is on all the time as long as its plugged in. Diode could be blown as a result of a lightning surge. Or open primary or secondary of the standby supply transformer.
But the last time I saw this it was due to a cracked circuit board interrupting the AC from the standby supply's transformer. |
Audiokarma |
I would look for a terminal on the PS board that says 5VSBY and see if you have it.
Also remove the PS board (might be difficult) and inspect all the connections. Does the board look like its been hot? Then check for bad caps. Have you looked around (on this here web) for a pdf schematic? |
Next step...
Put the PS board back in, turn it on, and probe around with a DVM to see if you have ANY voltages on it.
Be careful cause an inadvertant short can send the whole thing up in smoke. Might be conv board but you would most likely get a distorted picture first. I'd also sniff around for any unusual burnt smell. |
Get a couple of GOOD pictures of the boards...good enough for me to be able to follow things and I will try and tell you what to look for .
Will do. Just gonna take me awhile.
Audiokarma |
Just for kicks remove the conv board. (Make sure its been off for a while-like overnight) and power it up.
There are a number of posts regarding the conv board and even a repair kit is available. |
Not sure where the conv board is. The tdks are mounted on the same board as the fly back. I'll have to check it out later.
Should look something like this.
Audiokarma |
