I will plan to replace C20 and C21 with the below parts from DigiKey which have a temp code of XF5 and align with what SAMS specifies for replacements:
As for the SAMS test point D, that correlates to the Zenith Service Manual test point G. This test point is only used to feed the signal generator in as part of 41.25 trap alignment, for the remining IF alignment steps this test point is unused with nothing connecting to it. Before I order I will double check parts in the IF circuit. I also gambled and purchased on Ebay two claimed NOS 6EJ7 tubes. Thank you, Brad. |
Time for an update. I replaced C16, C20, and C21 which all measured 20+% low. I also spent some time swapping tube and seem to have found the right mix, note I did have a poor performing 6EJ7 tube. I might be getting closer, thoughts on what to try next?
Attempt 1 After going through all of the IF alignment steps I was able get the markers and attenuation to match the Service Manual overall response curve at test point C2. But when going back and remeasuring at test point C1 the 41.25mc marker is not at minimum and the response in-between the 39.75mc and 41.25mc markers seems large, not sure if this is concerning. See the image below: Attempt 2 Next I went back to test point C1 and found adjusting the 41.25mc trap was my best option to minimize the 41.25mc response while not messing up the overall response to bad, note the response in between the 39.75 and 41.25 mc markers is still large. Going back to test point C2 shows the 41.25 marker is not correct. See below: Last edited by bhegges; 12-27-2023 at 05:07 PM. |
For reference here is the SAMS IF circuit schematic with the Zenith Service Manual test points and coil/transformer part numbers. Also here are the abbreviated alignment steps:
Attempt 1 looks better than atempt 2, except - is it possible you have swapped C1 and C2? The scope response to the right of the Figure 12 C2 drawing looks like a reasonable video response.
The scope picture to the right of the Figure 13 C1 drawing has a peak at the sound subcarrier, 41.25, which it seems might make sense to feed the Sound-Sync amp, although the drawing doesn't show such a huge peak. Did you replace any capacitors in the sound-sync detector area? Particularly note C22 is a very small value, 0.82 pF. |
IF capacitors that could be in question:
Doubled checked C1 and C2 test points on underside, all is correct Maybe an issue: I retested R52 which is a 5% (gold band) 180 ohm that in and out of circuit measures 219 which is 22% high. I will replace, note I only have metal film resistors which some argue against using in the IF circuit. Last edited by bhegges; 12-27-2023 at 09:04 PM. |
Audiokarma |
R52 looks like it could affect the width of the 41.25 trap.
Looking at your two attempts again, I don't quite understand how readjusting L4 doesn't minimize the 41.25 response at both C1 and C2 simultaneously, resulting in the desired curves, but obviously it's not doing that, and is making one or the other worse. So, I'm puzzled and waiting to see the result of replacing R52. |
For the alignment directions I have been using the Zenith CM-106 Service Manual which covers the 25MC33 chassis, nearly identical is the CM-105 Manual which covers just the 25MC30 chassis, but there are a few small changes.
Alignment for T4 is slightly different, maybe...
My chassis is a 25MC33, note SAMS lists both chassis under the one folder. These two chassis are very similar with only minor circuit changes I could see in the schematic. Interestingly the IF section on my chassis is wired like a 25MC30.
Aha! These curves do show a peak between 41.25 and 41.75 at C2. It also looks pretty obvious that you swapped the C1 and C2 sweep traces in your previous posts.
Based on what you just posted, I would say the "attempt 1" traces look correct or very close. |
I am getting closer. I now am ensuring the sound detector (C2) voltage is at 2 volts and the video detector (C1) is at 6 volts. Over/under driving these voltages does affect the signal response. I also labeled the scope each time I snapped a picture so not to mix them up (label includes signal generator input and scope output). See below for where I am at:
The one concern I have is on the sound detector C2 response curve there is no real response dip like shown, my curve just starts to slope down continuously until it gets to the 41.75mc marker. Is it possible that I am still way off and need to push the 41.25, 41.75, and 42.75 further right on the wave form, that would put the 41.25 on the top of the first peak but currently is at 25% vs the spec of less than 5%. Last edited by bhegges; 12-28-2023 at 11:16 PM. |
Out of curiosity I adjusted L1 (41.25mc trap) and L3 (39.75 trap) to their max and I was able to get the below curve, all other coils and transformers I left as-is. It seems like if I had a bit more adjustment in the coils I could get the response curve to dip between the 39.75mc and 41.25mc markers. Also not sure then why such a response around the 41.75mc marker, while the drawing shows a bit of a curve here my set exaggerates the response around this marker.
Would there be a particular capacitor in these trap circuits I should look at? All of these capacitors are precision low values that are not easy to measure, I would have to remove the capacitors and either try to measure or just replace. I also could just move on. Maybe unrelated but after going through the power supply, horizontal and vertical circuits there was low sound and serious buzzing/noise in the sound circuit, the Quadrature, Intercarrier, and Sound Take Off coil all needed a good bit of adjustment. I still get buzzing/noise during screen changes such as when going to commercials. Last edited by bhegges; 12-28-2023 at 11:16 PM. |
Audiokarma |
"I am getting closer. I now am ensuring the video detector (C2) voltage is at 2 volts and the sound detector (C1) is at 6 volts. "
I think you mean "sound detector C2 and video detector C1" ? |
Yes, you are correct, I will fix my typo.
"Out of curiosity I adjusted L1 (41.25mc trap) and L3 (39.75 trap) to their max and I was able to get the below curve, all other coils and transformers I left as-is. It seems like if I had a bit more adjustment in the coils I could get the response curve to dip between the 39.75mc and 41.25mc markers."
When you say dip do you mean lower on the scope screen (actually an increase in signal)? Matching that blip is not important. What is important is that the response at 42.75 and 45.0 are equal, 45.75 is at 50%, 39.75 is practically zero (high on the scope trace) and 41.24 is high on the trace, at -24 dB or greater, which means less than 6% of the peak response. |
Also, 45.75 should be at 25 or 30% per the drawing, not 15% as in your last trace.
Correction: I meant 41.75, whihc I was reminded by later post is actually 41.67 in the B&K. Last edited by old_tv_nut; 12-29-2023 at 11:00 AM. |
I think I got it. Note the B&K 415 outputs a 41.67mc vs 41.75mc marker. I maybe could try to reduce the 47.25mc marker as it is not quite at zero. The peak to peak signals at each test point is still an interesting element as changing the amount of signal from the B&k 415 going into the tuner does change the response curves. I might try to measure the tv when it is normally running to see what I get.
C1 C2 |
Audiokarma |
