Old 05-09-2013, 07:11 PM
John Folsom's Avatar
The 8016 is just the developmental number for the 1B3. Same thing.
At <= 30KV, the X-Rays produced are relatively soft, and the glass of the mirror and the metal of the barrel are effective in stopping them. And if you keep the covers on the HV cage, likewise. But caution is advised. And distance is a good protector.
John Folsom
Old 05-09-2013, 10:34 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
I bought three WWII-dated JAN 8016's on ePay some years back. Anyone know what piece of gear they went in?
Old 05-09-2013, 10:36 PM
I removed the second 1B3 and hooked a jumper to the output of the first, then I installed a 5AXP4 test CRT, turns out it works very well this way.
I still have no control over the brightness but the "Picture" (Contrast) control does work, possibly the Brightness Pot is bad.
The Sync is all over the place but I was able to get it to hold still long enough to snap the picture below.
Unfortunately as the set gets hot the picture fades out, also I noticed the image is negative, not sure if the 5AXP4 has it's Grid and Cathode wired differently than the 5TP4 or if it's a problem with the chassis.
I haven't tested any of the tubes in the i.f./Vertical sweep chassis but I did swap out most of the relevant ones with no improvement, there are probably some drifted resistors somewhere.
Old 05-10-2013, 06:17 AM
cwmoser's Avatar
cwmoser cwmoser is offline
What does "blooming" look like?
I've heard this term but never really knew what it means.
Thanks
Carl
CW
Old 05-10-2013, 09:01 AM
jmetal88 jmetal88 is offline
Thanks
Carl
If it's being used the way I use it, it's when the picture gets larger due to increased brightness.
Old 05-10-2013, 10:13 AM
'Blooming' occurs when the high voltage drops signifigantly. Static attraction from the front of the CRT decreases, allowing sweep angle to increase or "bloom". The raster progressively dims and goes out of focus as it blooms.
The most common cause is a weak HV rectifier. Or excessive CRT beam current can lug the HV supply down (eg., from the brightness control being turned too high).
Old 05-10-2013, 10:19 AM
I feel like I'm getting off-topic (sorry), but thanks for that explanation. That might actually help me with the blooming on my set. The 1K3 rectifier was dead when I got the set, so I replaced it with a 1B3 I had lying around, thinking it would be 'close enough'. If it's outputting on the weak side, that might explain the weird blooming pattern I've been seeing lately.
Old 05-23-2013, 01:56 PM
cbenham's Avatar
cbenham cbenham is offline
Smile
Here's 4 pages from the RCA HB-3 Tube Manual showing the specs. for the 5TP4 CRT.
The limiting factor for this tube is that it can only dissipate 5.4 watts. This is determined by multiplying the Ultor operating voltage ~~27,000 volts by the beam current ~~200 microamps.
If this value is exceeded for a long time the heat developed can crack the faceplate. This results in what RCA laughingly calls a "catastrophic failure" of the CRT.
You can measure the beam current by connecting a 1000 ohm resistor in series with the cathode lead to ground and measuring the DC voltage across it. 200 microamps [0.2MA] would show a voltage of 0.2 volts.
It is always gratifying to see these projection sets restored because they represent an important step in the development of television.
Your restoration is specially interesting because you have done so much work
and very well to make this set look and operate like new again. Congratulations.
Old 05-26-2013, 07:58 PM
Don't forget the basics.
I have spent hours over a period of days trying to figure out why the Audio Amp in this set wasn't working, it was dead silent except for a very faint bit of static if you touched a screwdriver to the plate of the output tube.
I poured over the schematic, checking wiring, checking resistors, checking voltages, convinced I'd wired something wrong, I tried jumping the field coil in the speaker and using a PM speaker, I tried different sources and not a peep, voltages all looked good enough that it should be working but it wasn't!.
I had subbed the 6J5 where the signal comes in but I didn't test the 6F6 output tubes because no way could they be dead enough for it to be completely silent.
They had a nice getter and looked fine, anyway it's a push pull amp so if one is bad it'll still work on the other, and no way could they both be dead enough to kill the whole thing, could they?
Both 6F6 output tubes were completely dead, heaters lit, no shorts, no apparent gas, just absolutely no emissions at all. I couldn't find any 6F6 tubes handy so I stuck the first somewhat similar audio tube I could find in the amp, a 6L6 and viola, it worked fine on one tube. I dug up a couple 6V6's and plugged them in and the Amp is alive, of course now the TV chassis is somewhat dead waiting on a contrast control but one thing at a time.
Old 05-26-2013, 09:49 PM
Einar72's Avatar
I've had 3 or 4 of those amps, and I've never seen one where the green power resistors didn't look like they'd run hot. I finally got another 8PCS41 last year, and it came with a newer pair of 6K6's in it. Got a fair amount of audio while the plates were glowing! I'm assuming the owner who had it serviced used it this way for years.
Old 05-26-2013, 11:00 PM
One of the big green resistors was open, I don't think it was originally since they were all running hot to start with so maybe I blew it open while tinkering. I subbed it temporarily with a 2.5k @ 5 watts.
I'll have to look for some 6F6's, not sure I have any.
Will the 6V6 sub it on a permanent basis or do I need 6F6's? I tried a 6L6 also and it worked.
I'd like to get some in an ST bottle like it shows in the Sams picture.
Old 05-27-2013, 12:58 AM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
Didnt hurt my 37 Delco subbin the f6 with a v6....
SR
Old 05-27-2013, 07:40 AM
kvflyer kvflyer is offline
I believe that a 6V6 is a good substitute for a 6F6. The heater current of the 6V6 is .45 amps vs 6F6 which is .7 amps. So, you can use two 6V6s until you get a pair of 6F6s or keep the 6V6 in there.
Old 05-27-2013, 09:18 PM
Einar72's Avatar
They have the same 315 volt maximum plate supply voltage, but the 6V6 grid bias at maximum rating is only -13, while the 6F6 is -22, so there's less danger of it running too hot when biased for a 6F6. Values are similarly safe for push-pull configuration...
Old 05-27-2013, 09:39 PM
Einar72's Avatar
BTW, is there -21 volts on the Grid #1's?
