Old 05-26-2023, 01:51 PM
LukeSimon LukeSimon is offline
The multi lytics in the set are as such.
C1-A&B (80uf@450) are impossible to reach cause of no room, (filters)
C1-C is 20uf @ 350 and may be able to isolate and relocate as it's for the grid of audio output.
C2A 80uf @ 450 filter
C2B 50uf @ 450 filter on vert output
C2C 30uf @ 450 filter
C3A 20uf @ 450 filter bottom of voltage divider
C3B 20uf @ 450 filter video amp 1
C3C 20uf @ 450 audio out xformer
Just can't do anything to C1 w/o destroying it.
For my Magnavox T931, I used an oscope to measure the ripple voltage on each lytic that is used as a decoupling capacitor. They all measured good. I also did in-circuit ESR and capacitance tests and all measured good except those 2 on the convergence PCB. I bet after reforming, most are still within specification.
Old 05-26-2023, 03:08 PM
Perhaps they are OK, but I don't know yet, in most sets I have done so far many were bad, C4 was definitely bad and leaky testing a 2x norm value, C5 was also too high @ 81uf, (cathode cap vert output ) , now has new TVA1414-E3 Sprague ATOM.
I don't have one of those old fancy vintage cap leakage testers, wish I did, but from what I have seen, if the testers I DO have (I have 2) show the value to be way WAY above the posted value, chances are it's leaky and not to be trusted, like the example of the 100uf testing a 208 on both testers.
Old 05-26-2023, 06:40 PM
If you want your restoration to look OEM on the inside, you can get newly manufactured multi section can lytics from CE Manufacturing. I bought a new capacitor from them to replace C1, just in case it failed to reform.
Old 05-27-2023, 06:20 PM
Only 2 new tubes have come in so far, the mixer/ osc for the tuner, and the video amp V6 12GN7A, no change in the picture yet, VERY weak luminance that is overpowered by color.
In grayscale setup it does not take much turning up of the screens at all to make a bright line on all 3 guns, but when in normal mode, nothing is seen on the screen cause luminance is so low getting to the CRT. You have to turn the screens up too see anything at all.
3 good 6GH8As are coming, as is the 1st video amp cathode follower tube 6LM8 (V6)
I have not found any other bad resistors so far, hopefully this is just a case of tired tubes, as mentioned, they seem to be all original.
Old 05-27-2023, 06:51 PM
12GN7A tubes are one of the most impressive vacuum tubes to have been mass produced. It has a very impressive gain, and its plate can handle 12 watts. Not bad for such a small tube.
I think the luma issue is due to the weak 6GH8A blanker.
Old 05-27-2023, 08:00 PM
some sources say that 6LM8 and 6GH8A are compatible, but i am getting a new one of each anyway.
Old 05-27-2023, 09:30 PM
damen's Avatar
damen damen is offline
The 6GH8 blanker and the 6LM8 video amp really need to be 100% in these chassis. Earlier Magnavoxs did use a 6GH8 in place of the 6LM8s. Also, unlike most all other brands, the brightness control on Magnavoxs has an effect on the set up service line adjustment. I always start with brightness, contrast, and kine bias controls tuned down. After set up and tweeking adjustments, if brightness is lacking check resistor R74, on the cathode of the 12GN7 ( shown on your post number 51). The resistor is usually underneath the tube socket on the foil side of the board. The diagram shows a 470 ohm, some sets used a 270 ohm. On sets needing more brightness range I replaced the 470 with a 270, made quite a difference.
Old 05-28-2023, 01:10 PM
https://www.youtube.com/watch?v=XwJplJKppqc
2nd video
its pretty clear that the filters are not up to snuff.
Old 05-29-2023, 11:19 PM
http://suzaku.live-evil.org/magg1-cap.jpg
going to try and replace what Caps i can C2a C2c C3a
hopefully that will clear up that noise in the screen ( bar riding up )
Old 05-30-2023, 08:16 AM
USPS is living up to it's reputation of reliability and efficiency as always (heavy sarcasam ), as the new 6MD8, which should have been here today, decided to take a 1,800 mile sightseeing trip from the local PO 15 miles away, to Teterboro NJ, WAY TO GO, USPS!
Old 05-30-2023, 02:08 PM
kvflyer kvflyer is offline
Ya never know, it just might show up today!
Just sharing my frustration a bit with USPS.
30 May 2023 14:13
Arrived at USPS Regional Origin Facility. Your item arrived at our KEARNY NJ DISTRIBUTION CENTER origin facility on May 30, 2023 at 2:13 pm. The item is currently in transit to the destination. KEARNY NJ DISTRIBUTION CENTER ← Expected Delivery by 5/30/23 by 9pm, I DON'T THINK SO-- USPS!
USPS
29 May 2023 01:12
Arrived at USPS Regional Facility TETERBORO NJ DISTRIBUTION CENTER ← leaving on a jet plane, just for fun?
USPS
28 May 2023 12:58
Arrived at USPS Regional Facility AUSTIN TX DISTRIBUTION CENTER ← 15 miles away
USPS
28 May 2023 12:57
Departed USPS Regional Facility AUSTIN TX DISTRIBUTION CENTER ← it left before it arrived!
USPS
28 May 2023 03:50
Arrived at USPS Regional Facility DALLAS TX LOGISTICS CENTER
USPS
27 May 2023 11:27
Departed USPS Regional Facility CHICAGO IL NETWORK DISTRIBUTION CENTER
USPS
27 May 2023 01:37
Arrived at USPS Regional Origin Facility CHICAGO IL NETWORK DISTRIBUTION CENTER
USPS
26 May 2023 11:49
USPS in possession of item OAK PARK, IL, 60304
USPS
24 May 2023 15:52
Shipping Label Created, USPS Awaiting Item FOREST PARK, IL, 60130
Old 05-30-2023, 02:55 PM
If you think that's bad it's just a part for a hobby...
Our local state farm office was not getting mail into their PO box for MONTHS.... People's coverage was lapsing and their business was a mess because of this. For several months in a row our agent kept pestering them to fix it and getting ignored, the runaround, BSed, all the above until eventually someone noticed they had been dumping checks and sensitive legal documents into the wrong PO box for months! Can you imagine getting into an accident and discovering you don't have coverage because the post office wasn't delivering your check.
I get that they are having staffing issues, but at some point there needs to be punishment...If they have to worry about the last 2 months of their paycheck deposits being pulled back from their account or SOMETHING other than layoff that hurts then they'll be more careful.
Old 05-30-2023, 03:00 PM
Tom9589 Tom9589 is offline
USPS is not the only carrier to engage in long odysseys. I ordered an A/C hose from Phoenix, AZ. I live in the Atlanta, GA area. Fed Ex Ground routed it through Idaho! Come on guys - just get on I-10 and head due east.
Today, I ordered another car part which is being shipped from a town 7 miles away. DHL says it will be here on Friday. Before you ask, the company won't let me pick it up in person.
Old 05-30-2023, 03:21 PM
I'm just having flashbacks of when I tried to get a NOS vertical block transformer for my Arvin over 2 years ago or so from e-bay, the first one was lost when it got to the local PO, they never found it, the 2nd one was DOA, a bad one, used in a new box, which was lost on the way back RMA, the 3rd and final came from ETF, and I was very nervous tracking it all the way from Hilliard, OH, hoping that USPS would not mess it up as well.
