aaa
aaa
Im very jealous. Nice find!
Nice find, Tony
Hey, I have the same sign. They look great when lit up. Yours looks almost like new. Mine has some weathering here and there, but still presentable. I bought it in Washington state; it was originally used in a motel in Arizona or New Mexico.
Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html |
[aaa
Audiokarma |
Best way to remove the paint depends on the type of paint used -- which is anybody's guess. I'd start with the gentlest method and move up to harsher stuff if that doesn't work. They probably didn't use latex, but that can be softened by laying a rag soaked in paint thinner on it for a while; then you could gently rub off or scratch off with a fingernail, if lucky. Tougher paint may need something more aggressive. Whether the stronger solvent harms the underlying paint/plastic also depends on the type of materials used there. The standard advice is to test your solvent on a hidden or unobtrusive part of the object. Perhaps if you remove the frame, there is a normally-hidden edge of the painted piece that you can test. Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html Last edited by Phil Nelson; 07-21-2017 at 02:31 PM. |
I've heard oven cleaner is good at removing paint from plastic. YMMV
Denatured alcohol removes paint from plastic phone cords and hard plastic housings for me. Not isopropyl. Denatured alcohol is a pretty good solvent and kind to everything but Tenite and older 1950s plastics, but your sign has the 1969 RCA logo, so it's later.
DA could also remove some of the outdoor grime from the rest of the sign. But to be sure, try it in an inconspicuous place first, as you should anything that might damage or cloud the plastic, just to be safe, and see if any color comes off. I remember those signs from my days traveling with the family to Florida and Pennsylvania. First thing out of the car my sister and I 1) Found out if it was a color TV and 2) Found out what kind of ice was in the ice machine. I remember those RCA 19" TVs they used too. |
+1 on the Easy Off Oven Cleaner, used it to strip paint of a plastic TV Bezel.
As always test it first to make sure it won't dissolve the plastic. Citri Strip will ruin plastics. |
Sweet. A local shop went out of business a few years ago. They wanted a "starting" bid of $300! Nice catch.
Audiokarma |
Nice catch.They are hot as much as beer signs.I have a Sylvania sign from my friend shop in the garage .I hope you can get the RCA logo showing on it.
aaa
I'm jellyfish!
Let me live in the house beside the road and be a friend to man. |
aaa
Fluorescent Lamp for the sign
I take it you have the whole sign since you are asking about the lamp it takes?
I wound think a 36" (3' F30T8 or F30T12) Fluorescent tube would fit it. the ballast should also state the tube that is needed if the label is there and still readable Anyway awesome sign! |
Audiokarma |
