Old 01-25-2018, 07:30 PM
Captain Video's Avatar
Captain Video Captain Video is offline
Motorola 7VT-5B
Sooner or later I will have to pick up this set that I bought from a friend, it is a long 700 km trip, I will go either by bus or by car. Should I disconnect the CRT for transport?
Old 01-26-2018, 09:59 AM
At the very least, inspect the CRT and see if it is secure. Motorola used a really cheap mounting system where there is a clamp support on the neck and a foam gasket around the face. Often that gasket deteriorates leaving only the neck supported.
Rough handling could cause it to break as it did when I received this similar model VT71.
Old 01-26-2018, 04:59 PM
Yours came by mail or transport company? You didn't pick it up in person?
Old 01-26-2018, 05:12 PM
It came by mail. It was too far away to pick up in person.
Old 01-26-2018, 06:35 PM
Interesting that most if the funnel and face are intact... I would have guessed that the box would have been filled with small pieces of glass.
