Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > General Off Topic Forums
Old 05-24-2013, 08:18 PM
Reece's Avatar
Reece Reece is offline
Re: dirty air conditioners, on the way back from West Texas I stopped at a motel in Junction, Texas, last summer. It was an inexpensive place but recently built and very clean and comfortable, with new looking furniture, fridge, microwave, etc. But the A/C / heat unit under the front window smelled of mold. It blew cold air, but I knew I couldn't stay in there as the smell was making me sick. I went to a local supermarket and bought a giant can of Lysol. Came back and shut off the A/C, pulled the front cover and filter, and hosed down the coil and drain pan with almost all that big can. Let it sit turned off for about an hour: the room stayed cool. After being turned on, it didn't smell any more. Not an ideal cleaning, but OK for one night. I know the drain pan must have been full of it and maybe partly clogged.
Reece
Old 05-24-2013, 10:22 PM
Dude111 Dude111 is offline
Analogue is Awesome
Originally Posted by josephdaniel
Anyone got any old or other wise ancient air conditioners laying around or stories they would like to tell about em???
Yes I am very thankful to have an OLDER AIR CONDITIONER!!!!
They use FREON and produce MUCH COLDER AIR!!!!!!!!
Old 05-25-2013, 08:35 AM
Did you tell the management about the problem?
They're wide open for a lawsuit. Some people are more subject to resperitory infections.
They probably never heard of "Legionaire's Disease".
Old 05-26-2013, 01:19 PM
Reece's Avatar
No, I didn't tell them; I should have.
Reece
Old 01-16-2017, 10:02 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Resurrecting an ages old thread, I finally found one!!!
From what I can tell, it's a 1959 Westinghouse Mobilaire mode MCA-117C. Note the original stand has the cursive Westinghouse logo on it. The whole thing is spotless!! I've been keeping a casual eye out for one this old for years and have never seen one before. I wouldn't imagine there are many left out there of this vintage.....these pics were taken prior to cleaning and polishing....but as you can see, it wasn't even that dirty
All I needed to do was clean the thermostat and she fired right up. And this sucker puts out some COLD air. The most awesome thing about it is that when I run it the whole basement smells like the inside of an old felt lined projector case. I so love that smell. Everyone that knows what that smell is knows exactly what I'm talking about
Old 01-17-2017, 05:56 AM
jstout66 jstout66 is offline
I LOVE it! What a "Cool" find.
I keep a casual eye out as well, but like you said.. not many are out there.
I wonder what the back story is on yours. How it got kept, AND with the stand!!?
I wonder if it got kept as a spare?
Old 01-17-2017, 08:42 AM
DavGoodlin's Avatar
Motorola Minion
Great find Tim - Along with style and marketing, Westinghouse A/C units were also tough and might have most beat in durability.
That was probably built at the Mansfield Ohio plant. Maybe the compressor has some patents from Carrier and others
Westinghouse was a world power when it came to electrical infrastructure, likely scaled down to make that unit last this long. Two start capacitors, easy to replace, not part of the sealed compressor.
-Dave G
Old 01-17-2017, 09:47 AM
Only one capacitor is used for the compressor, the large one. The smaller one is for the fan motor speeds.
All the sealed compressors used an external capacitor. Single phase air conditioner compressors were permanent-split capacitor start.
The compressor could be a Tecumseh pancake type. Almost indestuctable!
Old 01-17-2017, 03:26 PM
Olorin67 Olorin67 is offline
I know of 2 houses built in 1958 that have original GE heat pump systems that are still running.
Old 01-19-2017, 04:04 PM
DavGoodlin's Avatar
Motorola Minion
Not surprised at all considering how their old fridges hold up.
-Dave G
Old 01-20-2017, 10:21 AM
They really weren't intended to be used in colder climates like Wisconsin, as they don't work below 28 degrees F.
They're using them more around here for smaller homes, but they have back-up resistance elements, that automatically take over when the outside air is too cold.
