Old 07-02-2021, 02:37 PM
1935 GE Model A-53 AM/SW Tombstone Radio
Hello everyone this past weekend I picked up at one of my favorite antique shops near me a 1935 GE Model A-53 AM/SW tombstone radio that needed some work done to it (it was missing the power cord, had a blown out flexible Resistor R-11 a 450 ohm 1W Flexible Resistor, some bad capacitors a bad tube and an incorrect rectifier tube).
I've got the radio completely recapped but dummy me forgot to order a replacement resistor for the blown out Flexible Resistor, which I would assume a 470 Ohm 1 Watt Flameproof resistor would work in place of the old flexible resistor?
Thanks for your help.
Old 07-02-2021, 08:47 PM
I can't see why a 470 ohm, 1w resistor wouldn't work. It's in the cathode circuit, of the audio output circuit. The rectifier tube can be a 5Y3, 5W4 or another 5Z4.
I have one just like it! It's a strange non-AVC superhet, with the volume control that isn't in the detector circuit.
Old 07-03-2021, 01:54 AM
Well, this one had a 5U4GB in it in place of the 5Z4 Rectifier tube, and all of the tube substitution books I have show that the 5Y3 and the 5W4 are not substitutes for the 5Z4 tube, and neither is the 5U4.
Is it common for those old flexible resistors to just blow apart? I'm asking because this resistor's outer cloth shell was completely disintigrated and all that was left was the resistor's wire element which then shorted to the chassis and left a burn mark on the chassis where it shorted to the chassis!
Also as for the replacement resistor I did come across in my parts stash 2 270 Ohm 2 watt flameproof resistors that I tied together in series to make a 540 Ohm 2 watt resistor (the original resistor had no tolerance markings listed so I figured that that would be close enough.
the original 6A8 tube (this radio had all metal cased tubes which were brand new at that time) was completely dead according to my tube testers (I tested it on my Knight Model 600 Tube Tester, my Sencore Mighty Mite VII Tube Tester and on a B & K Model 606/666 Tube Tester and all three of them tested the tube as bad/zero emissions), thankfully I had a NOS 6A8GT tube that I was able to stick in there, hopefully it won't affect the performance of the radio with it not being a metal cased tube like the rest of the tubes.
You said this radio doesn't have AVC or a standard Volume Control configuration, how does this radio perform compared to others in your opinion? I like to use these radios for Night Time DX'ing.
Old 07-03-2021, 10:32 AM
The 5Z4 is a real odd-ball tube! The first ones looked like a ballast tube, with a perforated metal housing and two sealed capsules in it. They only made it for a short time, as they were failure prone. The newer 5Z4's were like a metal 6F6. As I stated, the 5Y3 has a 5volt 2amp heater and the same pin-out. The 5U4 has a 3amp heater and too much current for the power transformer.
Regarding the flexible resistor, they all crumbled after so many years. I would use two resistors to equal a value closer to 450-470 ohms.
When DXing with a TRF or a non-AVC superhet, you have to have the volume control set to max, to have the sensitivity to seek out distant stations.
If the radio squeals or motorboats, you might have to use a tube shield on the 6A8GT.
Old 07-03-2021, 12:35 PM
Well it seems that this radio may not work with an unshielded 6A8 tube in the set as the radio just hums/motorboats really badly when fed a signal from my signal generator or any other kind of signal and unfortunately I don't have any tube shields that are large enough in diameter to fit over an octal tube and short enough to go over a 6A8GT tube so that the gridcap can go over it...
when I have the original 6A8 metal tube in the radio it doesn't do anything (no audio or anything) but then when I turn off the radio I can hear my signal generator coming through loud and clear and undistorted (no hum/motorboating), which tells me that they wired this radio up so that it could only use metal cased tubes I think...
As for the resistors, I already have the 2 270 ohm 2 watt reistors installed in the radio, and I don't really want to have to go back in and remove it and reinstall new ones again as it was a pain in the butt to install them the first time around, is there any sort of problem with having a resistor that's 70 ohms higher than the original? The original resistor as I said previously didn't have any sort of tolerance listing listed for it in the Rider's Service Data which usually means its at least 20% tolerance or more, and 20% of 470 is 94 ohms which means that 540 Ohms is well within the original specs...
Old 07-03-2021, 06:32 PM
That statement usually pertains to carbon resistors! Wire wounds are usually pretty close. The flexible ones are wire wound.
Old 07-03-2021, 12:57 PM
If your crafty you can make a temporary shield out of aluminum foil to use till you can find an appropriate original...
Old 07-03-2021, 04:03 PM
I was able to jury rig a tall octal tube shield by cutting it down so that it was the appropriate height and it still seems to be having issues with motorboating when a signal is applied to it with my signal generator, it basically just hums like mad when a signal is fed through the radio, either through the grid of the 6A8 tube or through the antenna wires, and the hum goes away when you tune away from the signal, and also the hum gets louder or softer depending on how you adjust the gridcaps on the 6K7 and 6J7 tubes, any ideas as to what might be going on here?
Old 07-03-2021, 06:25 PM
Did you ground the tube shield with as short of a wire as possible?
Also, was any component drastically relocated in the convertor or IF circuit?
The servicing instructions state that the set could be unstable under certain conditions.
Maybe you have to wait until you can obtain a metal 6A8.
Old 07-04-2021, 01:32 AM
The only "alterations" I made to the IF and converter circuit was replacing the grid cap wire leads for the 6A8 tube and the 6K7 tube because the wire leads for the wire leads were dry rotted and had exposed wire.
Other than that when I replaced old capacitors and resistors I put them back where they were originally in the circuit (I completely unsoldered each capacitor from their respective tie points and soldered the new capacitors back in where the old ones connected originally).
The only components I relocated were the two 8 MFD electrolytic can caps that were bad (the ones on top of the chassis), I disconnected the components from the old capacitor leads, and then took a terminal strip with a blank mounting tab (mounting tab with no terminal attached) and soldered it to the terminal on the old can cap that way the components and the new capacitor was isolated from the old cap but was mounted in a convenient spot.
I reattached the wires/components and the new capacitors to one of the isolated terminals on the newly attached terminal strip and attached the negative lead of the new capacitor to the chassis just like the old ones were, and I made sure that the leads from the new capacitors were as short as possible.
The only other thing I can think of is that maybe when I installed the new wire leads for the grid caps on the 6A8 and 6K7 tubes I might of made the leads too long, but it was kind of hard to know how much lead to use especially on the 6K8 tube's grid cap lead because I had to go from under the IF can to the top of the 6K8 tube which is about 2 inches, and I think I may have cut about 3 inches of wire lead because I wasn't sure how much I needed for sure and I didn't want to cut myself too short.
Could having too long of grid cap wire leads cause the issues I'm having?
Old 07-20-2021, 01:39 PM
DavGoodlin's Avatar
Motorola Minion
I had a look at the schematic and the 5000 ohm volume control seems to vary suppressor grid voltage on the 6K7 IF tube.
-Dave G
Old 07-20-2021, 04:23 PM
Looks like it also ties to the cathode and to the 6A8 cathode. So applying varying positive voltage on the cathodes equates to varying neg. voltage on G1s (control grids).
Old 07-20-2021, 05:28 PM
Well I'm not sure about the volume control and whether or not its original or not because its the same exact volume control pot as what's in my Philco 116B which is from 1936 and unfortunately it has developed the same "sticking" power switch issue as the power switch on my Philco 116B has.
The volume control/power switch pot on this radio is a CTS (Central Telephone System) Type T Power Switch/Volume Control Pot, which seems seems to be a trouble proned volume control/power switch pot, because actually come to think of it this humming issue is exactly what my Philco 116B did which I thought it was bad filter caps but now thinking upon it I'm now wondering if it wasn't maybe a bad volume control pot, which I'm now wondering if that's not the case here...
CTS by the way has a plant in Elkhart, Indiana which is not too far from where I live, which is actually where the two aforementioned pots were made.
Old 07-25-2021, 05:10 PM
I had acquired late last year, more or less the sister set to this radio the RCA 5T and that thing when I first acquired, would blow the breaker for the circuit my workshop was on in my house, (and he told me that's all it did for him as well, and that was why he was selling it).
It was because the previous owner of the set a fellow antique radio enthusiast/collector had at one point replaced the original cloth cord with a modern lamp cord but he didn't wire it up right, which was why it was blowing the breaker, and it took me a few months of studying the Rider's Manual and the old RCA Red Book service diagrams for this radio to figure out that the wiring diagrams for the switch on this radio on those manuals (or at least the Rider's anyways) were written incorrectly and had the "dummy terminal" on the Power Switch marked in the wrong spot which is I think why the previous owner had issues with the wiring of the RCA 5T I am currently writting about.
Anyways the RCA 5T I just got going is a great performing set, its super sensitive and selective and the SW band on it picks up stations like its nobody's business (I was picking up the WWVB time stamp signal @ 5 MHz, I was picking up many Religious Stations on the SW band, and I was even picking up Radio Havanna out of Havanna, Cuba on it!
Anyways my point is that some of these old radios are super easy to repair and troubleshoot and some of these radios are a pain to troubleshoot even using the best troubleshooting skills one has to offer.
Actually calling the RCA 5T the "sister radio" to the GE A-53 is kind of inaccurate because the 5T is a vastly superior radio to the GE A-53 in many ways including the fact that the 5T has a great performing AVC circuit, whereas the GE A-53 lacks any sort of proper AVC circuit.
Old 08-13-2021, 12:08 PM
A little update:
I think I may have found a replacement switch/volume control that might work on this radio, someone gave me an old junker Philco Model 60 Cathedral Radio from the same time period as this GE is from (1936) and it also had a CTS Model T power switch/volume control assembly in it, the volume control pot on this switch/volume control is a 500k Ohm (.5 Meg) pot and I was wondering if this might be a viable replacement (even though this radio's original pot was 5k ohms) would the 500k vs. 5k make that much of a difference in how this radio performs?
Any help in this matter would be appreciated.
Thanks.
