1967 Magnavox U-919
Good morning. I have a 1967 Magnavox console with the U-919 chassis. What are some things I should look at that might cause low B+ voltage?
If its a voltage doubler PS there is one can thats insulated
from ground & usually cardboard covered. Common to open. Other than that quite a list of things. 73 Zeno |
Have you changed the lytics, how does the rectifier tube (if it isn't SS) test, any paper caps left in it?
The set is all tube, and is still all original, except for most of the tubes.
