Old 04-12-2023, 02:00 PM
DavGoodlin's Avatar
Motorola Minion
Tektronix 516
I have an issue with the Intensity control not having much effect on brightness, then all traces fade out after 10 minutes.
The schematic shows a circuit that controls bias on the CRT via R828, a 1 Meg.
Could it be as easy as one bad resistor?
-Dave G
Old 04-12-2023, 04:41 PM
The image is really hard to read. Are you referring to the resistor in series with the intensity control?
Also, have you checked the three rectifier tubes?
Old 04-12-2023, 07:51 PM
Better images here:
https://w140.com/tekwiki/wiki/516
I would suspect the 3 caps near the intensity pot.
Old 04-17-2023, 08:49 AM
DavGoodlin's Avatar
Motorola Minion
Thanks!. I will try the 5642's, I have a spare as well.
-Dave G
