Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > International Vintage Televisions
Old 01-07-2016, 06:51 PM
RetroFormat32's Avatar
RetroFormat32 RetroFormat32 is offline
1971 HMV Trent problem.
My 1971 HMV Trent television works, aside from one weird video problem. It seems that the vertical or something is screwed up, as it won't center when I use a digital signal like a converter box. Only on analogue signals it will stay centered.
Old 01-07-2016, 07:11 PM
It's TRYIN' to tell you something, but you AREN'T listening... (Grin)
Old 01-07-2016, 07:19 PM
Lol. I am turning 18 this year and hopefully I am going to rock this restoration, whether it is a bad tube or not.
Old 01-07-2016, 09:45 PM
If it a monochrome or color set? Mono sets typically have centering rings on the yoke, color sets typically have a control.
Is synch at black or white video level in your country? Here in the USA synch is black, and sets with poor synch detectors and vertical stages tend to loose centering or roll on letter boxed VS. native 4X3 content. Could be synch separator, vertical (more often drifted resistors/bad caps than tubes), or the AGC could be misadjusted.
Old 01-07-2016, 10:13 PM
Monochrome. We did not get color until 1975.
Old 01-08-2016, 05:26 PM
Do you still have true over-the-air analog signals in your country? What country are you in? The output of the "converter box" is an analog signal itself, but it could still be different enough that your TV set has trouble with it.
Old 01-08-2016, 07:08 PM
Is you system 625 lines 50 frames/sec. Before color became popular, your system was known as the CCIR standard.
Some refer to it a PAL, which only pertains to the color system, Phase Alternating Lines.
In the US, we had color since 1954, but it didn't start getting popular until about 1963/64. That's when more color programing became available.
Old 01-08-2016, 09:15 PM
The set is a VHF only set, which sucks...
Old 01-19-2016, 01:01 PM
Robert Grant's Avatar
Robert Grant Robert Grant is offline
And a VHF only tuner in a 1971 set?
Would I be right if I guessed you're in Australia?
Okay, I need to ask if your picture is merely off-center (but steady), or rolling (moving up or down the screen and reappearing on the other edge of it).
If it is steady, try the settings on your converter box (usually accessed by the remote control of the converter box) and try different "aspect ratio", "zoom", "display type","shape", "PAL", "NTSC", "50Hz" or "60Hz" settings.
If it is rolling, the sync signal is not as strong as the sync signal on analogue television broadcasts had been. Perhaps try a separate RF modulator (which could be a VCR) instead of the converter box's own.
If your television has valves, try replacing the valve that controls vertical sync.
