Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > Introductions
Old 05-14-2014, 12:57 PM
OxfordGlenn OxfordGlenn is offline
Sony kx-1901
Hi, New to VideoKarma. Great site! Just found my first high end TV that I stored at parents home for years. I purchased this SONY KX-1901 new and it is in it's original packaging with all of the things that came with it when new. Any market for this unit? Where is the best place to post a vintage SONY monitor only? It has RGB inputs and built in stereo amp with 10 WPC per side.
Old 05-15-2014, 04:16 PM
HI !
Good to see ya-
There is a market for everything, If you wanna sell it, try craigslist, and or ebay.
ebay will give you close to market value......
Old 09-02-2014, 08:29 PM
loui loui is offline
Hi glenn, I'm actually interested in this monitor, since you said it had rgb inputs?
In any case I've sent you a PM
Old 09-05-2014, 02:03 PM
mpatoray's Avatar
mpatoray mpatoray is offline
The RF input on the XK series of Profeel monitors is a IDC-34 connector, like on a floppy drive. The KV-1311CR had the same connector.
The RGB signal can be either digital or analog, the digital is TTL digital and conforms with the CGA standard.
Analog RGB must have a standard NTSC scan rate, there where adapters for the Atari ST and Apple IIgs to allow the RGB input to be used with those computers.
Old 09-06-2014, 02:13 AM
Does this mean the monitor is usable with other 15khz inputs? Or can it only accept rgb from microcomputers
Edit: Apologies, I'm assuming by standard you mean 15khz because correct me if I'm wrong the atarti and apple are both 31khz?.... if so that means I would essentially need to build a cable, but at least I know it is do-able
Thank you mpatoray
Old 09-08-2014, 01:22 PM
mpatoray's Avatar
The Apple IIgs has a 15.7 kHz scan rate. I thought the Atari ST did but I could be wrong on that one.
Yes the KX series of monitors are fixed frequency, its 15.7 kHz or nothing.
Old 01-07-2015, 12:01 AM
mariamunir mariamunir is offline
ill have to post some of my 70s collectable gear sometime(didnt think anybody liked that tech yet)-most of my 50s and older gear are not "daily drivers" but the 70s and newer tech keeps going everyday!
Get fast success in learn how to speak spanish and learning spanish for kids
Old 02-01-2015, 10:18 PM
DavGoodlin's Avatar
Motorola Minion
The 70s and 80s equipment has standard ICs and transisitors, so it is more serviceable by far than anything made later.
It gets much respect on this forum because it keeps going AND it's repairable by even jack-of-all trades techs like my self.
I enjoy tube equipment more but it requires maintenance and occasional repairs.
I have two once-wonderful Onkyo Integra series AV receivers from the 90s that have issues with protection shutdowns, a feature rarely found in the 1970s.
After checking ESR on capacitors and ribbon cable connectors, I haven't a clue, so they will sit until I join AK.......
-Dave G
