Which model (or chassis) of RCA color TV is this?
This set has the same tuner panel (with the single channel selector knob, and the slide-rule UHF channel indicator with the orange pointer and aqua channel numbers) as my grandparents had when our TV at home was only black-and-white, and I remember it quite well - really, really wanted a color TV in our home.
I think their set was the same as this, about the same size, though theirs may (or may not) have had some wooden decorations along the top at the front of the set. My mom had always said that this was one of the last "roundies", and that most color TV sets were rectangular even when Grandpa bought his. I always had assumed that this would have been a CTC-16 set as it was one of the last RCA chassis for a round tube produced in large numbers. However, I recently found a brochure for 16s online, and none of them had the tuner panel like on the set I've pictured here. Unfortunately for me, this set is in a museum (worse, it's just sitting there, unplugged, on the floor, standing alone, and not part of any exhibit), As you may have guessed, I would like to find a set like this. I happen to have a 21FJP22 that tests excellent on a tester. What models of RCA sets looked like this? |
I believe the last Roundie produced was a CTC-20
"It's a mad mad mad mad world" !! http://www.youtube.com/user/mwstaton64?feature=mhee |
I don't think it's RCA made. RCA did have the same basic metal face panel, and 4 knob cluster below the tuner on the CTC-16 and CTC-20, but they also sold those metal face plates to MANY smaller firms (I can show you a Silvertone CTC-15 clone as proof) which often used their own tuners and tweaked the tuner portion of the panel (and sometimes more of the control section) to fit/make theirs look different. GE was one company that took only the face plate, Admiral sold RCA made sets with cosmetic differences until ~1963 (IIRC) then made their own color sets.
The last by RCA, at least.
Yes that's what I meant. I have an Admiral roundie that was made in 1967 as a price leader. Was $299. All original local set and still works
Audiokarma |
removed
Never seen a selector knob like that on one.
Speaker grill & metal plate look RCA. Maybe a Canadian RCA ?? 73 Zeno |
Can't say for sure that it was made by RCA, but positively, unequivocally sold as an RCA (though it can't be seen in the web-resolution photo, the escutcheon above the UHF channel scale reads "RCA Victor").
EDIT: One possible clue: The VKer known as "old tv nut" has an animated avatar of a set with the same bezel, only with a "chromed" knob driving a tuner with a backlit channel indicator. The mystery RCA is likely an economy version of his set. Last edited by Robert Grant; 02-09-2016 at 08:37 AM. |
hi guys it is a rca ctc 16x or a ctc20. ctc 17 used almost the same but rectangular
RCA, as well as others, made sets for a particular customer as a short run, leader model. That model was probably the real last run of the 20's. Ages ago, I had trouble finding a channel selector knob for an RCA. The RCA distributor had to call the factory to cross- reference the model number. The factory said, it was a special order set for a large store chain. |
Audiokarma |
There is one on Craigslist in your state. See third picture. http://detroit.craigslist.org/mcb/atq/5559913545.html
How many 6gh8 tubes are in this one?
One is too many...
Though I have heard from multiple sources that the 6GH8 isn't a bad tube at all, it's just that RCA chose to run the snot out of it as far as ratings are concerned. Fortunately for us the 6U8(A) is a suitable sub, so I just replace with those and never had a problem. I don't keep cases of 6GH8's around the house, but I have plenty of 6U8's.
Evolution... |
Or get Sylvania 6GH8 tubes. RCA started using them later since their own manufactured 6GH8 tubes were not up to the challenge... or so I have heard. (You know, hearsay...)
I've seen some made by Westinghouse and GE. OEM, white printing.
Audiokarma |
