Car battery charger regulation
I have an older Motomaster (Schumacher) model 11-1159-4 6-amp manual battery charger. I would like to use it to power my car stereos on the bench. Any suggestions on what to use for outboard voltage regulation?
Besides the voltage, you'll get lots of hum from a battery charger, unless you hook it to a battery to smooth things out.
Even with a battery, you'll get some hum - I had my Honda Accord in storage for a while, and had the battery go down. I used my lil' Shumacher battery charger to charge the battery, and tried the radio while it charged - pure 120Hz hum.
It's probably best to hold out for a regulated 12/13.8V power supply - an Astron, an old Archer (Radio Shack), a Pyramid, or any one of the many off-brand supplies. I pick them up at flea markets - many sellers can't guarantee them or hook them up, so I offer what I'm willing to pay and usually it's accepted. Cheers,
Brian USN RET (Avionics / Cal) CET- Consumer Repair and Avionics ('88) "Capacitor Cosmetologist since '79" When fuses go to work, they quit! |
I have a "DVE" model DVP-112 power supply here... the output is only 2 amps and I have no idea if it's regulated. Would that be good enough for old car stereos?
If it is a 60Hz transformer and diodes style unit try a 2200uF 25V+ cap on the output...I use that and a 70's Tripplite 500W inverter/battery charger to run car radios with little hum.
Audiokarma |
I assume it's that type... it's quite heavy for its size and hums a little when powered up. It's worth a try, thanks.
I used to have a Pyramid-branded supply. It was supposed to supply 12 amps constantly, yet it wouldn't power a high-beam headlight. My battery charger will power it, and only about half of the available 6 amps are used, go figure.
From a review on eHam:
jr Last edited by jr_tech; 05-22-2015 at 07:36 PM. Reason: add link to reviews |
For bench-testing car stereos, I use a PC power supply. They usually have a decently strong 12v rail. Even a little 350w has a 13A 12V output (and a 12A 5v should you ever need it).
What self-respecting nerd doesn't have a pile of PC power supplies laying around? |
This one. AT supplies are hard to come by here, and I'm still not sure how to keep ATX supplies going without a motherboard attached.
Audiokarma |
You just jump the PS_ON (pin 14, usually a green wire) to the common (black, usually right beside it).
Also, don't forget that you can come up with some weirdo voltage combos with all the assorted rails, just mind your chassis ground reference. Examples: using the hots of the -12V and +12V rails will give 24V between them (max current here == max capacity of -12v rail, not usually a lot, 100mA min, 300mA average...) Need 9V? Easy to access using the +3.3V and +12V rails. (Yes, yes, 8.7V isn't 9V... Close enough!) How about some "A" battery? +3.3V and +5V, give 1.7V between them... That will extend filament life compared to 2V. (Switching noise is posibly an issue here, don't have any working farm-sets to verify with...) The possibilities aren't endless, but there's a whole buncha different ways. Quote:
They're usually all quite thoroughly hosed though. (Skulls for the Skull Throne, etc.) We keep the one known-good unit that is on-hand in a secured location. Last edited by NoPegs; 05-26-2015 at 05:25 PM. |
I'm more of a math and science nerd, so any computer part that's no good has to go.
I still have the charger, but selected this a while back for car stereo use and whatever other ~12 volt device I may want to use indoors. It powers my headlight just fine, which draws about 3 amps. I'm curious about how much a low-beam light would draw.
Halogens are usually in the 55 watt range for low-beam and 70 watt for hi-beams. I can't speak for the sealed-beam types but my initial thoughts would be "At least as much as halogens, probably quite a bit more because they're less efficient." Suffice to say the fuse for my low-beams is 10 amps, and high beam circuit is 15. Strictly speaking your rather handsome boatanchor there could run all four of my bulbs and still have a bit of margin left. |
Audiokarma |
