Old 10-17-2010, 03:27 PM
aquaman8 aquaman8 is offline
VK Member
Help with a Sencore TVA92
Good Afternoon Gentlemen,
I am not sure if this piece of equipment is vintage enough to post here, but I am out of sources. If someone could recommend a more suitable site then I would try there! In the interim, here goes!
Bought the unit on eBay...description said problem with B+...so I knew it needed some attention. Turns out that when I got it many things did not work, principally the DVM. When set to BIAS VOLTS, I get some -8.8 to +17 over the range. The output on the jacks is 0 to 30 VDC as it is supposed to be.
Anyone know what common faults with this unit are or where I could go on the Web to find assistance?
Thanks for your time,
Mitch
Old 10-17-2010, 08:00 PM
Findm-Keepm's Avatar
Followin' the Rules...
You might want to compare the metering circuit to that in the VA62 - which also has a similar bias supply. I fixed an "unfixable" VA62 simply by swapping the A-D converter chip around in the socket (it was put in backwards by the previous tech that deemed it "unfixable")
Sencore wasn't likely to design a different metering circuit for each or their products, so most likely, the VA62 and TVA92 are alike. Phil Nelson has a VA62 and may be able to provide some help.
IIRC, the VA62 meter circuit has some input protection diodes - I've seen them go bad as well. The SC61 meter also has the diodes that go bad - perhaps they duplicated this as well in your TVA92?
Wish I could be of more help - I've only played with a TVA92 at a Sencore Sales Presentation/Tech Training Seminar. Bitching Unit - sub the complete horizontal/sweep section of a TV (sans IHVT)!! That and their LCR meters impressed me the most.
Cheers,
Brian
USN RET (Avionics / Cal)
CET- Consumer Repair and Avionics ('88)
Old 10-18-2010, 04:37 PM
VK Member
Hi Brian,
Thanks for the response. I will have to look for a schematic for the VA62 to check out the meter section. Any ideas where I might find one?
Hopefully there will be some similarities between them, but the VTA91 is an electro-mechanical nightmare with a lot of microcontroller controlled relays switching sources and attenuation, and relays always make me worry! There are also many opto-isolators used to keep high voltages away from sensitive digital lines! Quite a troubleshooting adventure! I'll keep everyone in the group informed as to how things go!
I will also check out the diodes, thanks for the tip!
Any ideas if there is a Sencore repair group/forum around on the web? Hopefully this will be a common fault and someone can point me in the right direction! I' hoping!!
Thanks again for your response,
Mitch
