Old 03-20-2017, 11:07 PM
Sounds like you're going to have some recapping fun. I just took a look at my 11 chassis and the B+ is the red/white wire on that terminal strip lug closest to the back of the chassis. The red/green wire is where to two diodes anode and cathode join together in the center of the terminal strip. Those two 160uf caps along with the two diodes form the voltage doubler, so they definitely need to be healthy and reasonably matched in value caps. I just rebuilt the can caps in my 11 two weeks ago and they are not the easiest things to get at.
