Greetings from Washington D.C. USA
Hello! I look forward to delving into the great resource that is Videokarma. I have spent more time at AudioKarma but have had occasion to pop in here at times.
I have a circa 1935 Crosley 555 radio which belonged my grandparents. This hould be a fairly straightforward restoration as it is is intact and complete. I recently was given an incomplete 1935-36 Zenith 9-S-54 console radio, chassis #5903 which is missing the 12" Field Coil speaker. My first thought was to replace it with a modern 8 Ohm coax driver, and introduce a 2K Ohm resister and choke coil to the circuit. The tuning belt is nonexistent and the recommended supplier closed his doors Jan. 1st. The coarse tuning knob spins on the shaft. I have not looked more closely for other issues. I also have an old crank wall phone that may just get cleaned up and hung. My wife loves the look of antiques and supports my hobbies so I may acquire other items if I have the opportunity. I do have a background in electronics, circuit theory and repair techniques. Been awhile since I used some of it. |
Welcome to VK!
Ham shack...AM side: Knight-Kit T-60, RME-45 Vintage SSB side: National 200 Modern SSB: Kenwood TS-180S MFJ tuner, 130' dipole |
Welcome.
Some advice on the crosley from someone who last year did a similar chassis. They used oddball 3 terminal dual section paper caps...be careful to understand the wiring and install the replacements properly. What you propose on the Zenith is a valid approach....Spaekers for zeniths are obtainable and putting a want ad on the antique radio forum will get you more help than VK. Using a choke for the field coil is more advisable but a resistor will work. Check the hardware stores for a good sized rubber or silicone O-ring to replace the belt.
Try to source that one! |
Glad you're here. I collect Zenith and Philco '34 to '40 radios. I especially love my rare Philco 37-665B.
Rick (Sparks) Ethridge |
Audiokarma |
Hello! Welcome to the forum!
Hey, I'm in stafford I think I have a field coil 12. I'll check wed.
Thanks for the warm welcome. Life interfered with my free time so I'm hoping to get to these gems as the weather turns cold. I am putting together the parts lists including wiring. I got my hands on a Magnavox 12" field coil speaker, 1000 ohm rather than the 2K ohm Zentih 49-120. I think with a resistor this will work to get me started without modifying the remainder of the circuit. Still on the hunt for the real thing.
Nice t'have ya ! Welcome !
Benevolent Despot |
Welcome!!!!!
Audiokarma |
