Old 10-20-2022, 12:41 AM
YamahaFreak's Avatar
YamahaFreak YamahaFreak is offline
<-- CSXT 6038, EMD GP40-2
Samsung PN50C550 single horizontal line
This TV has been working flawlessly for a few years now, ever since I got it secondhand and replaced the failed power supply. I turned it on today and there is suddenly a single pixel tall horizontal solid black line, almost exactly halfway up the panel, running all the way from edge to edge. It is consistent and does not move, flicker, or change color. I went inside and reseated all cables and connectors - no change. Ideas? Please don't tell me my panel is bad because I love this TV!
Sony Trinitron Fan
Old 10-20-2022, 07:18 AM
kf4rca kf4rca is offline
That's a plasma. I'd check power supply voltages first.
Old 10-21-2022, 10:36 PM
I'm not sure how the power supply could be at fault. The only defect is that single pixel dead line, and the power supply has already been replaced and verified working.
I'm thinking it might be a buffer issue. Otherwise, I'm out of ideas.
Sony Trinitron Fan
Old 10-22-2022, 06:56 AM
Here's a link to a samsung plasma training manual:
https://www.eserviceinfo.com/downloa...0%5BTM%5D.html
I don't think it's panel. My experience is the panels are pretty robust unless, of course, it's cracked.
Old 10-22-2022, 03:22 PM
Thanks for that link, sure to be useful in the future! Panel is definitely not cracked, as it's running (otherwise) just fine, no other changes, and no physical shock has been dealt to it. I did once read about issues with cracks spontaneously developing in Samsung plasma panels, but have not seen any evidence of that happening on this one.
Sony Trinitron Fan
Old 10-27-2022, 12:28 PM
Try soldering up the driver boards. They run pretty hot and can develop cold solder joints.
Where's JohnCT? I think he's an expert on these.
Old 01-13-2023, 01:33 PM
JohnCT's Avatar
JohnCT JohnCT is offline
Sorry, AWOL...
With a plasma, a single horizontal line is either the buffer board (95%) or the display itself. I can't honestly recall seeing a display itself cause this but some training manuals over the years mention it, so I am as well.
John
Old 02-03-2023, 05:26 PM
Originally Posted by JohnCT View Post
Sorry, AWOL...
John
A little update: the line is still there, and has not grown, moved, or otherwise changed at all. Definitely a fixed anomaly. I'm a bit concerned about it affecting the panel as far as burn-in is concerned.
Sony Trinitron Fan
Old 02-07-2023, 09:16 AM
JohnCT's Avatar
The line is unlit, so if you ever replace the scan buffer board to restore a complete pic, you'll find the line is now a bit brighter and a bit bluer than the rest of the display, depending of course on how long the display is run with that one line unlit.
John
Old 02-28-2023, 02:54 AM
John
I actually wanted to go that route (replace the entire buffer board) but none seem to be available. Alas...
Sony Trinitron Fan
Old 03-02-2023, 08:41 AM
JohnCT's Avatar
I have one if you want it - I don't take these in anymore for service.
Part number LJ92-01729A
A couple of caveats. The 50C550 is a 1080P panel and the ribbons from the panel to the buffer board are a bit difficult to remove and difficult to seat in the connector. When I install them, I use an Optivisor to make sure the ribbon's two notches are seated fully down in the connector. They may look good at first but when you see them with magnification, you'll see what I'm talking about. If you're nearsighted then this won't be a problem.
This board was marked good by me which means it was either pulled from a running panel or tried in another panel and verified, so it *should* be good.
If you want it, it's yours for the asking.
John
