I've also used lacquer thinner and rubbing alcohol to clean motor bearings. All of them seems to flush out the gunk then flare nicely when finished.
"When resistors increase in value, they're worthless" -Dave G |
Lighter fluid is just Naptha - it'll evaporate down to the additives within 2 days.
For cleaning shaded pole phono motors, we gave them a ssquirt of Naptha, let that drain, then another, letting it drain onto a clean paper towel. That let us know when all the dried stuff had broke free. No need to soak. One done, give each bearing a BB sized dab of Phonolube from GC. No oil necessary, unless you have a Dual-branded changer with the oil impregnated bronze bearings - light machine oil for those. BSR, Garrard, Zenith, Collaro, and VM all used Phonolube. It has a service life of about 8-10 years before it hardens.
Brian USN RET (Avionics / Cal) CET- Consumer Repair and Avionics ('88) "Capacitor Cosmetologist since '79" When fuses go to work, they quit! |
To relube the bearings, I put them in a small steel Del Monte fruit cup and covered them with a half-inch of fresh Mobil SAE 10W-30 motor oil. I covered the cup with tin foil and set it on a pie plate on top of a saucepan with boiling water, to heat the oil and the bearings. After 20 minutes, I turned off the heat to let the oil seep back into the pores of the bronze. When everything cooled to room temperature, I fished out the bearings and reassembled the motor. This was well over five years ago and the motor has run cool and quiet ever since.
Tom |
