Old 11-25-2011, 08:31 PM
Sweet! Scored a nice Samsung 32" LCD
This 2008 Samsung showed up at the Thrift store a couple weeks ago, price was $225 Remote included, not too bad if it was working but this one was dead.
Today was 1/2 off on everything, still too high to gamble on at $112.50 so late in the afternoon I made an offer of $50 and it was accepted.
I took off the back and found (what else) one of the Caps had blown it's top, only one and it's an oddball looking one that's a different brand than all the others so maybe the others are OK.
It's a 2200@10v, I had a 3300@ 6.3 on hand so I put it in and now it works!
The 6.3 volt cap is running cool but I'll get a correct cap before I button it up.
This will make an excellent bedroom set, it has mounting holes for a wall mount.
Here's are some pics.
Old 11-25-2011, 10:44 PM
stereorob stereorob is offline
Banned
cool! a lcd tv for 50 bucks? cant beat that!!
Old 11-26-2011, 12:56 PM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
Looks like a 2200 uFd/16V 105°C Low ESR cap would fit the bill there. I wonder how many LCD sets get junked for a capacitor?
Old 11-26-2011, 02:23 PM
NJRoadfan NJRoadfan is offline
LOTS if its a Samsung. I have a 19" one here thats sitting in the basement. Eventually I'll spend the $30 and see if its a bad power brick (its external). There really aren't any caps in the set itself, I think the small PCB the power switch is on is bad though. Getting replacement parts, or even another dead/broken monitor has proven impossible.
Old 12-30-2011, 01:29 PM
VintagePC's Avatar
Tube bug got me 05/2010
If it's a 960BF, check the surface mount fuse. Those can go bad and prevent the backlight from coming on while the rest of the display still works.
Also, just to add to the thread. Had one of my 206BWs die. Bad caps in the P/S, so I ordered up some and did an across-the-board replacement on all three of those monitors I have.
Two were made at the same time, and had bulging caps, the third was made a month later, and had a different panel, and the caps were fine.
Replaced them anyway for peace of mind.
Old 01-08-2012, 01:09 AM
Found a nice wall mount today at the Thrift and now I have it set up in my room!
Is that "The Room" playing on that TV?
Its a SyncMaster 930MP, a combination TV/computer monitor. It powers up, but usually just gives me a blinking power LED (indicates standby). Sometimes it'll give me video. When it does work, it will never go to standby, even if the computer goes to power saving mode and cuts video output. Annoying because I like this monitor. It has SCART RGB in (rare in the USA) and its a multi system TV (takes NTSC/PAL/SECAM video input). Plus its 4:3, and supports 720p HD video (1280x1024 native panel res.).
I replaced it with a 940MW (its 1440x900 19" widescreen cousin), which also has documented cap problems. The biggest difference is that this model has the power supply built into the monitor vs. a brick. If I ever have a problem with it, the model was popular enough to market re-capping kits which are readily available on ebay.
Old 11-26-2011, 06:06 PM
Looks like this is a very common problem for this model.
I typed the model number into Google and most of the hits were of the "My Samsung won't turn on" variety.
Fortunately it's a very easy fix.
The insides of this set are amazingly bare, compared to my Plasma which is packed full of circuit boards and components this almost seems like Magic that it works!
I realize of course that there are actually millions of transistors and whatnot etched into it's little Silicon organs.
Old 11-30-2011, 12:18 PM
I recently read in "The Basics of HDTV" that most flat panels today are in fact packed with circuitry, though most of it is unnoticed because it is contained within integrated circuits (ICs). In fact, I was amazed by the sheer numbers of circuits contained in these chips when I saw the block diagrams of the sections of a typical HDTV. Who would have thought, 25 or 30+ years ago, that this much circuitry could be crammed into a very small IC chip, or that an entire television could fit into a cabinet under one inch thick?
More amazing, to me anyhow, is how today's FPs can be made so slim. My own Insignia 19" flat set is only about an inch thick, if that much, and weighs just under 6.6 pounds without the table-top stand. I was amazed when I set up this TV in place of my 12-year-old analog one; the flat set is so much smaller it all but floored me. I bet a lot of non-technical people, used to seeing a large console or table-model TV in a huge cabinet, are amazed as well that such a small device as a modern FP (even a large-screen one) is a "real" television set. Because all FPs bear little or no resemblance to the large portable, table and console television receivers that preceded them (and which most people old enough to remember them are used to), such a reaction would not surprise me.
What is probably more amazing to a lot of people is the idea of hanging a TV set on a wall, like a piece of framed art. This used to be science fiction (who would have so much as dreamed, 40 years ago, of doing that with a heavy 1950s-'60s vintage portable?), but today's FPs are light enough that it is now possible to do so -- even though it takes a special type of mounting to safely attach a FP to a living-room wall. The online instruction manual for my FP (and probably every flat-panel ever made which is intended for wall mounting) makes a specific point of this, and cautions the set owner that "one size [of flat-panel television wall mount] does not fit all" as well as stating that only a wall mount capable of supporting the set's weight must be used, lest the set falls off the mount (when the latter breaks under excessive weight) and shatters into a million pieces. I've never actually seen this happen, but it may well have happened in the past when someone does a slap-dash job of mounting the set to the wall or uses a flimsily-built (or the wrong size) wall mount.
Old 11-30-2011, 12:48 PM
In the 60's I would not think that mounting a set on the wall was sci fi. There were large deflection angle monochrome CRT sets coming out in the last couple of years of the 50's that were VERY thin. Infact I have an ad for a compact GE monochrome TV stereo console where they say that it can be set on a table, on the floor (with optional legs), or HUNG ON A WALL.
Infact I seem to recall reading a vintage article where an industry man is asked about what he thinks TVs will be like in the future, and he says that he envisions that eventually Tvs will be thin enough to hang on a wall.
Old 12-01-2011, 11:45 AM
Mounting television receivers on walls may not have been science fiction in the 1950s-'60s, but, IMHO, it wouldn't have been practical for large sets (21 inches on up, as I will explain below). The reason is that most sets of that era, particularly table sets and the few portables available then, were in rather large, heavy metal cabinets with a cap on the back cover for the CRT neck. I doubt that such sets could be wall mounted because they were so heavy, and also because of the CRT cap. Any wall mounting arrangement for most '50s portable TVs would have to be made to support 50-60 pounds, as most of those sets weighed the proverbial ton. My aunt had a 1950s-vintage RCA Victor 17" portable (the same type of set as in VK member Adam's avatar) that must have weighed 40 pounds if it weighed an ounce; that set had a power transformer, 5U4 rectifier, and an all-metal chassis and cabinet. If this set were to be wall-mounted, the mount would have to be extremely sturdy; of course, any set larger than that would need a custom-made wall mount. I'd be extremely leery of wall-mounting a 23-inch 1950s table model B&W set because even the best and sturdiest mount made can fail -- and if a 23-inch or larger (!) CRT implodes when the set hits the ground .... I shudder to think of it. I would mount such a set in the wall instead.
The idea in the 1950s-'60s of a combination TV/radio/phonograph that could be wall mounted sounds incredible. How on earth did GE build that set so light and compact that the whole thing could be mounted on a wall, without causing the heck of a safety hazard? How many of these combos were made, and for that matter, how many different manufacturers made sets like this? I would guess not very many, and of those that were sold, I don't think many of them wound up on walls -- I would imagine most folks who bought these also invested in the optional legs, and used the sets as consolettes. RCA offered some of its mid-'60s metal-cabinet color sets (I had one) that had threaded holes in the base for legs, sold separately from the TV itself.
BTW, the man in that vintage TV article you mention was right on, as today's flat panel TVs are thin and light enough to hang on walls; in fact, a lot of folks do just that. I know someone who did this with a 70"(!) flat panel and turned one entire wall of his living room into a large-screen movie theater.
Old 12-12-2011, 10:20 AM
JCFitz JCFitz is offline
Some of the plasmas especially the older ones like my Vizeo 42" that only had 6 dry caps and I got it for free weigh on the order of 90 lbs or more.The wall mount is rated for 135 lbs. Luckily I have pretty thick sturdy walls. My 2009 Sony 32" lcd in the bedroom is light as a feather compared to the living room tv. It simply sits on its stand on my dresser.
Old 12-12-2011, 11:15 AM
Ed in Tx's Avatar
Mounting television receivers on walls may not have been science fiction in the 1950s-'60s, but, IMHO, it wouldn't have been practical for large sets (21 inches on up...
Not ON walls, but IN walls was what several family acquaintances and a couple of neighbors did back then, pretty popular thing to do. I can recall several who cut holes in walls and mounted the TV flush with the wall and framed it in, with the set in an adjacent closet, room or in one case I remember the TV was sticking out into the garage.
Old 12-12-2011, 12:34 PM
In an old issue of, IIRC, the (now long defunct) Electronics Illustrated magazine, there was an article in which a TV repair technician told the story of a service call he made to a home with a recreation area in the basement, frequented by the owner's friends who were sports nuts and enjoyed betting on games. In that rec room was a wall in which were mounted several TVs, one of which had a shorted CRT. When the technician arrived, he turned on to a local UHF channel the one set that had been reported as defective, and found a smeared picture, which would intermittently clear when the neck was tapped. However, I remember how the article ended. "When I left," the technician wrote, "they still had on the UHF channel -- broadcasting continuous stock market tapes!" I guess the owner's friends followed the stock market closely as well.
Replacing old worn-out TV chassis in big 3-way consoles was also popular in the '70s. Two of my great-uncles, both long deceased, had large combo consoles in which the television chassis failed after 25 years or so, developing expensive repair problems, so they decided to replace the TVs with modern sets -- retaining the stereo components. Both consoles were RCAs; one set's TV was replaced by an Emerson table model, the other's television was replaced by a Zenith CCII, IIRC. I wish I had pictures of the converted sets, as the conversions were very well done; they both looked like factory jobs. Today, the only way to even come close to having a 3-way entertainment center is to buy a large armoire or EC cabinet (or a stand, like I did with my components and which I still have, now with a flat screen TV on the top shelf -- replacing the RCA CTC185 which once graced that spot) and install your TV, video and stereo components in it.
We will never again, unfortunately, see the likes of the large, stately 3-way consoles popular in the '60s and '70s, the trend now being towards nondescript-looking FP sets on their jet-black stands. The only things that make today's FPs look good in modern living rooms/dens/family rooms when they are turned off, IMHO,are the entertainment-center cabinets or stands in or on which these sets are often mounted, along with a VCR, DVD player, and often a 5.1-channel AV receiver. An old friend of mine has a floor-to-ceiling entertainment center in his family room (which is huge), in which he mounted his TV (formerly a large Toshiba CRT, now a large FP), DVD and stereo system. I saw the installation some years ago when he had the CRT TV and was amazed at the size of the EC cabinet -- but I guess I shouldn't have been so surprised, since his family room has very high ceilings.
Old 01-30-2012, 06:49 PM
Keefla Keefla is offline
Yep, early 70's (71 or 72) issue. i have about 30 of them, including the one with that article in it. My father gave them to me about 10 years ago when he was cleaning out some of his old college books.
Old 11-30-2011, 01:05 PM
This flat CRT design is from the 50s... The Aken CRT:
http://www.videokarma.org/showpost.p...7&postcount=41
