Old 03-18-2008, 08:14 PM
Kiwick's Avatar
Kiwick Kiwick is offline
slave to 3 equines
Sony Trinitron monitor
Hi you all.
My 2000 Sony HDM-200 trinitron monitor has slowly lost horizontal width over the years, now i'm just right at 96% and i have very little H.W adjustment left... the geometry is otherwise excellent.
I have already resoldered the entire chassis about 4 yrs ago as it had some assorted intermittent faults, it worked fine since then...
Is this one a simple fix or maybe i'm about to lose the flyback?
Old 03-18-2008, 08:25 PM
MRX37 MRX37 is offline
You probably have a resistor or capacitor drifting out of tolerance.
If you can find the bad part, it should be an easy fix.
Old 07-23-2012, 05:32 PM
Kiwick's Avatar
slave to 3 equines
I have to bring up this thread again as the monitor is now displaying some annoying retrace lines in the top 2 inches of the screen...
maybe the CRT is starting to go?
Old 07-23-2012, 06:33 PM
holmesuser01's Avatar
I would suspect capacitors in the vertical deflection circuit, bad soldering, or bad soldering at the vertical output IC.
Old 07-23-2012, 06:53 PM
Kiwick's Avatar
slave to 3 equines
hmm the retraces first appeared today but they seem to disappear after the monitor has warmed up for a half hour or so...
This monitor is 12 years old and has lots of hours on it... it's amazing it's still working and displaying a good picture!
Old 07-25-2012, 07:39 PM
Kiwick-
Your description of the retrace line behavior (going away after warmup) exactly matches what happens with one or more bad electrolytic capacitors in the vertical circuits. If you or a friend has even basic electronic repair/soldering experience, you should be able to find and replace the bad ones. Likely, they have part numbers in the 500-599 range, based on other Sony monitors.
