Old 12-21-2017, 11:10 AM
Tom9589 Tom9589 is offline
Dieseljeep, you are right about the higher voltage tubes failing more often.
I used to amaze customers of series string sets when I would get the set working after subbing only one tube: the damper. Dampers just took a beating and failed at a high rate.
Old 12-22-2017, 03:37 PM
I've done it both ways. Many times you can't get at the entire bottom of the chassis or PC board. The PortaColors are a classic example. I usually go for the higher voltage voltage tubes in the string, but that isn't always true.
BTW, those PortaColors sure are nasty to totally disassemble to replace the CRT.
Areas covered with plastic, especially GE's, were why dikes were invented !
Also found damper most likely followed by a tuner tube. For the tuner
part of string find the brown wire ( most sets ).
Never did a jug on a PC. Only ones changed were under warranty.
GE had a way of "pouring" parts into a set without a care in the world
that someone would have to fix it some day. When the started building
some great stuff they were soon gone.........
Old 12-23-2017, 04:12 AM
1911nutjob 1911nutjob is offline
Yes. So the customer cuts the prongs to fit...........
All kidding aside we changed all modified cords as a CYA step. They
are redundant as everything is plastic. No effect on operating the TV.
BTW some chassii are hot either way......
As for doing a B&W first just get your set to be as good a B&W first
then worry about color.
Series string sets to find open filament do this.
Meter on AC, ground one lead. Go along pin 1 & 12 til you find one
with no AC on one pin.
BTW you will measure 120VAC all along the string. That will not match
the data. Its because with the open there is no current so no voltage
drop along the string.
Good call, appreciate the tech info and won’t waste my time with b&w. I’m gonna set up a Flickr account shortly so I can get some pics going for you guys.
Old 12-23-2017, 09:30 AM
The only reason B/W sets were recommended was to get your trouble shooting skills up to speed. I have several B/W sets, but if the program is in color, I prefer to see it in color. When I first working on TV's, I never seen a color set, except in the stores and there was seldom anything on in color. The B/W pictures on the color sets didn't compare with the pictures on the B/W sets of the day. I'm surprised that they sold as many sets as they did.
Old 12-23-2017, 02:13 PM
WISCOJIM WISCOJIM is offline
You don't need Flickr. You can post them directly to VideoKarma using the Attach Files feature on the Reply page. That way if your hosting site ever takes a dump, hopefully the pictures will still remain here.
Old 12-25-2017, 07:23 PM
Here goes. If this works, these are pictures of my restored set. Merry Christmas everyone!
File Type: jpg 22F4EEDF-ECE9-434E-8D5D-A18DA9150AA8.jpg (78.2 KB, 60 views)
File Type: jpg 4834EF50-6731-4A35-831E-3AC2EC76FCE7.jpg (29.5 KB, 51 views)
Old 12-25-2017, 08:30 PM
It's amazing how some of the sets that didn't have that much collector's interest before, can receive that many inquiries at this time.
An important piece of color TV history and design.
Old 12-27-2017, 03:09 AM
My newest arrival, courtesy of another member here. I’ll post pics of my parts set when I’ve cleared a path to it.
File Type: jpg B88EB33D-06C5-458F-83A1-5D5F60E91D9E.jpg (80.2 KB, 41 views)
File Type: jpg 35C9E0BE-430E-42AE-859E-6E7063DBCC93.jpg (68.6 KB, 35 views)
Old 12-27-2017, 09:41 AM
'That's the hi-voltage focus model, HE chassis. Probably that last of the production run. I have two of this model. I didn't change the boost filter caps in my two yet. .1 mfd @ 1000 volts. It's located on the side of the HV cage, instead of the PC board, like the earlier models.
Old 12-27-2017, 12:58 PM
Old 12-27-2017, 06:52 PM
Did you try the set out? It looks like it's in rather decent shape.
I haven't tried my PC's in a few years. I just fired up one of my later models and it looks pretty good. AFAIC, it's still better than watching B/W. The sound is better than many of the small import solid state sets.
Old 12-27-2017, 08:50 PM
dishdude's Avatar
dishdude dishdude is online now
I like the cabinets on the later ones. Looks like it should be solid state...lol
Old 12-27-2017, 11:04 PM
Thumbs up
I had to wait a day to let it recover from a cold soak on the porch, it’s bitter cold here in NW Indiana this week. But yes, it works surprisingly well with no strange noises or smells and the pots are relatively clean. It was demo’d for me immediately before packing so I was really just worried about it surviving shipping. Before I peek inside, does anyone know the tube lineup for this model?
Old 12-28-2017, 09:38 AM
I know of two CRTs for the Porta Color sets: 11SP22 and 11WP22. Was there a third CRT used in these sets?
Old 12-28-2017, 10:18 AM
The weather hasn't been exactly a treat here! Below zero at night, single digits during the day, with a nasty wind.
Where in NW Indiana are you located?
The tube compliment is about the same as the older models with maybe a few changes, HV rectifier etc. CRT is designated under the newer standards, 10V. IIRC, 10VABP22A.
