Old 07-11-2018, 01:16 PM
Zsuttle's Avatar
Zsuttle Zsuttle is offline
Motorola TS-4J
Can someone confirm what should attach to the selenium rectifiers? Someone replaced mine but there are a lot of loose connections and I'm not sure what goes where. The schematics don't match the spare chassis I have (TS-4J as well).
Thanks,
Zach
"If it isn't broke, you aren't trying hard enough"
Old 07-11-2018, 04:35 PM
I've restored several of these and the published schematics are correct. What differences are you seeing in your spare chassis ?
Old 07-11-2018, 05:21 PM
Zsuttle's Avatar
Maybe I'm reading this wrong, but the positives of C2A and C1 should never touch right?
This is the actual wiring of the spare. I realize this isn't in proper schematic form, but I didn't wanna confuse myself.
Old 07-11-2018, 05:25 PM
Right the positives do not touch - the rectifier goes in between. Your spare isn't wired right. Maybe someone was trying to fix it ?
Old 07-11-2018, 06:41 PM
Zsuttle's Avatar
We can only guess. The spare had numerous evident repairs. It blew both the diodes when I installed it in the main chassis, but hopefully all of the caps are still within tolerance.
Old 07-12-2018, 06:37 AM
If the caps you mention you hope are still good, then if they are original they won't be.
Old 07-12-2018, 11:21 AM
Even if those caps are new if the wiring errors put reverse polarity or AC across any of those caps the ones that got it are done for.
Old 07-12-2018, 05:26 PM
kvflyer kvflyer is offline
And if you don't take that into consideration, you may have headaches in the future. I realise it is difficult to throw away a "new" capacitor. But they are really not that expensive and there is security in knowing that they are new, and not stressed.
Old 07-13-2018, 09:21 PM
mrjukebox160 mrjukebox160 is offline
If C79 shorted the 200 ohm part of the ballast resistor should of burned up very quickly.
Old 07-13-2018, 09:33 PM
Zsuttle's Avatar
If that isn't the case, if anything at all had shorted, then the ballast should be blown right?
What should the voltage coming off of pin 4 and pin 3 be?
Old 07-14-2018, 06:53 AM
I don't find a c79 power supply cap on the ts4j schematic.
Old 07-14-2018, 10:42 AM
I think he meant C97.
I just spent a half hour trying to find the B+ source. It seems it's sourced from the cathode of the 12SN7, 2nd clipper.
Slightly harder schematic to understand! Even the Sams isn't much better.
Old 07-14-2018, 11:24 AM
The TS-4 family created the B+ rail by using several stages between B++ and B- as a voltage divider. You know how some makes used the audio output as a voltage dropper instead of a resistor...Moto took it a step farther by using several tubes in series-parallel to make a voltage divider. Crazy but it worked.
Old 07-14-2018, 12:35 PM
Zsuttle's Avatar
I was referring to C79 on the SAMs schematic(TS-4J Late). It's a little rf bypass connected to pin 3 on the ballast though it's located right behind the tuner.
Old 07-14-2018, 10:04 AM
Almost full line voltage because of no load.
That set's a little trickier to troubleshoot because it uses a floating B- line instead of a hot chassis.
