Sylvania 140 tube tester
I was just wondering if anyone else here has or had owned one of these. They were produced in the late 40s, so we know the limitations. I did find a .pdf file with scroll updates taking me into I believe the early 60s.
This was my first tube tester and I bought it for a song in the early 80s when almost anything tube was junk. It has performed flawlessly ever since. I have seen a lot of testers and have quite a few, but I have never run into another one of these. The dial glass broke years ago, so I have to be very careful with that until I get another piece of glass. Probably just go have one cut. There is one on Ebay for $89.00, so they are out there. I wasn't looking for one though. More just seeing what other people know about them. The one for sale is listed as a "Dynamic tester" which is I don't know for Dynamic Mutual Conductance. I don't see evidence that this is a D.M.C. tester as there is nothing but the usual controls on it. No micromho, english,or other indication of anything but emissions tests, but who knows. My "state of the art B&K Dynajet 747B has none of that either and is supposedly a D.M.C. tester. The 747B in all it's solid state glory seems to be a good, bad, shorts, and grid leakage tester. Maybe a topic for another thread. The old testers like that are great for vintage radio, 50s TV, and from what I hear guitar amp tubes can be tested on them. There must be settings for EL-34s out there which I'm sure are just based on a similar vintage tube. I think a lot of amps use 12AX7s as well which have been around forever.
"Face piles of trials with smiles, for it riles them to believe that you perceive the web they weave, and keep on thinking free" Last edited by Tubejunke; 03-25-2015 at 02:17 AM. |
I used to have a Sylvania 140 for a number of years. It is indeed a Dynamic tester, not Dynamic Mutual Conductance. It is supposedly better than a simple emission type tester but not as good as a mutual conductance tester. From what I have found it is basically a re-packaged Jackson 648.
Sean - WØKPX |
There were a lot of testers that seem to be in between a pure emissions test and a full mutual conductance test. Usually they appplied a voltage shift to the grid, so you do get some indication of how the grid affects the plate current. If you have to push a button to get the reading its usually a tester of this type. testers like these will catch tubes that have grid issues better than a simple emissions tester that just tests everything as a diode. If you cant afford a Hickock, they can still be a useful tester.
OK, wow; I didn't know that there was ever a go between although some of my descriptions may suggest that. The Sylvania seemed like a little more than average, but lacked some of the gadgets that I find on my Hickoks' which I have enough of. The Sylvania is frankly easy to use and has always proved to weed out bad tubes.
"Face piles of trials with smiles, for it riles them to believe that you perceive the web they weave, and keep on thinking free" |
