Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > International Vintage Televisions
Old 11-01-2016, 07:56 AM
RetroFormat32's Avatar
RetroFormat32 RetroFormat32 is offline
HMV F5-A6 "Ascot" TV. looking for a CRT and speaker..
I now am the proud owner of a HMV F5-A6, the "Ascot" From '57 to '59. it is right behind my pedalboard. i need a new CRT and speaker, and it is missing the power cable as well. mine was made on the 11th of July in '57
Sent from my iPhone using Tapatalk
Old 11-01-2016, 08:42 AM
Any speaker the same size and impedance will work.
As for the CRT you need a CRT type number. Did it test totally dead? If it is weak you may still be able to coax a good picture from it albeit maybe you'll need a brightener.
Old 11-01-2016, 09:52 AM
Too bad! The set's a little on the rough side or is that "Tattie".
Old 11-03-2016, 04:13 AM
The socket is damaged, the thing where the pins go in is totally necked. So I need a new CRT
Old 11-03-2016, 09:58 AM
The CRT could be a 21ALP4, 90 degree type, commonly used in the later 50's.
The Aussie sets seemed to use USA type CRT's.
Old 11-03-2016, 06:54 PM
duodiode's Avatar
duodiode duodiode is offline
Duodiode
Correct CRT
The correct picture tube for that model is the European type tube AW53-80. This would have been made by Philips at their plant in South Australia. I think it is unlikely that you'll be able to find a replacement unfortunately.
Stuart
Old 11-03-2016, 07:20 PM
I'd look for a compatible American type and try to import one if I were you. 21" monochrome American consoles are nearly the bottom of the collector desirability scale here and still dirt common.
Old 12-28-2016, 12:11 AM
irext's Avatar
irext irext is offline
Have you tried the Australian Vintage Radio-TV forum at https://vintage-radio.com.au/? You might have more luck.
