Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > General Off Topic Forums
Old 03-18-2018, 01:50 PM
init4fun's Avatar
init4fun init4fun is offline
Something I just thought of , It was in a compartment of a tube caddy that also had a degausing* coil , if that gives any possible hints as to it's purpose ?
* I have no clue how to spell "degausing" , but there were two of those and the mystery object in that same compartment ....
Old 03-18-2018, 02:01 PM
I just checked, and it's too big to fit the back holes in the edge magnet mounts in my CTC-5, but maybe it would fit another model?
Old 03-19-2018, 09:57 AM
Steve D.'s Avatar
Steve D. Steve D. is offline
Maybe it's an adjustment tool for the pots inside the pencil box area of the CTC5. They were dual pots, the rear one adjusted with a small screwdriver, the front one with a some kind of special tool. Looks like that item would do it.
Here's the CTC-5 dual pot adjustment tool:
-Steve D.
Old 03-19-2018, 10:03 AM
-Steve D.
A friend had one of those! I thought RCA would've made one as well.
Was that tool made by GC or Walsco?
Old 03-19-2018, 10:17 AM
Steve D.'s Avatar
Tool has Walsco printed on the handle.
-Steve D.
Old 03-19-2018, 06:15 PM
Beats me. Trouble is most techs that used it are dead now.
Reminds me of other special tools in the biz. Remember
these ?
Inside out socket for Maggies
Fork pronged tool also for Maggies
Anode lead removal tube for Sony coax HV leads.
Square driver for Zenith antennas & tuner gears.
Those Motorola transistor screws.
The 3 slotted driver for Zenith & others.
And last but not least ISO phillips screwdriver set to get out Jap screws that
would otherwise strip..........
Old 03-19-2018, 06:34 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
-Steve D.
Two of my sets have a pot like that for color temperature and green drive. Adjusting the color temperature is rather awkward with any tool I have; it isn't flush mounted so I just turn it by hand.
Old 03-20-2018, 11:02 PM
Popester's Avatar
Popester Popester is offline
Here is a thought. Could it be a part of the tv/radio/phono that has the pilot light? I have a Thomas stereo that when powered up a clear red transparent rod goes back to the pilot light that is on the chassis. Maybe it something along those lines.
My wish list:
Sony KV-7010U
Sony KV-1220U
Old 03-21-2018, 03:05 PM
init4fun's Avatar
A very good possibility indeed !
It very well could be a part of an RCA device , like you say perhaps part of some elaborate dial light rather than being a tool . It's funny , since it was found with TV tools rather than TV parts I automatically thought it had to be a tool , but as you say the very real possibility is that it could be a component rather than an instrument .
Hmm , so maybe it WAS a part of something , that the guy kept around to poke & prod at powered up boards as suggested earlier in the thread ?
Thank You Popester for presenting an interesting take on the mystery RCA , , , thing .
Old 03-21-2018, 03:31 PM
Are you coming to the Early TV Convention in May? If you bring it there, you might find someone who recognizes it.
Old 03-21-2018, 03:34 PM
How about a tool for manually turning a tuner on a remote set that had no knob on the front?
Old 03-22-2018, 11:57 AM
these ?
That lousy inside out socket that Magnavox used was really a treat!
I tried removing a chassis from a Mag stereo that had those. They were cranked so tight from the factory, I couldn't remove them without the proper tool. I called Mag and it was NLA.
The Motorola screws were clutch-head screws.
The cheapie Harbor Freight Phillips screw-drivers are fine for ISO screws.
Old 03-23-2018, 05:30 PM
init4fun's Avatar
I'm sorry I missed your question earlier , I will not be at the convention but if anyone there sees this thread and knows what it is I hope they post the answer .
