Old 04-14-2018, 09:38 AM
Ray Sieracki Ray Sieracki is offline
Blue Fox
Emerson model 108
Hi ,
I have a Emerson model 108 in white plaston coming my way. Does anyone know if a reproduction back cover is made. If I had a tracing of it ,I would cut one out. But I'm thinking I may be able to even find one. It looks like a lot of radio cramed into a small cabinet. I'll use a dropping resister to.get rid of the curtain burning cord.
Best Regards, Ray
Old 04-14-2018, 10:20 AM
WISCOJIM WISCOJIM is offline
The back on a 108 is made of the same material the cabinet is made of, so I doubt if anyone has been able to reproduce one.
Old 04-14-2018, 10:47 AM
Originally Posted by Ray Sieracki View Post
Hi ,
Best Regards, Ray
An AC capacitor voltage drop for the heaters is better than the resistor idea. An 8mfd @ 250VAC would be fine.
It's not an easy thing to source, but they're around. Still better than a resistor.
Old 04-14-2018, 10:58 AM
Blue Fox
Thanks for the reply and info. on using cap instead of the resistor like I was thinking of doing.
Ray
Old 04-14-2018, 09:43 PM
If anyone is into using Amazon, it's a great source for the caps, under 'Ceiling Fan Speed Control Capacitors'.
Old 04-14-2018, 10:31 PM
Blue Fox
I see that one was exactly that 5-8 uf at 250 volts.
And they look small enough as not to take up alot of room .
