Some interesting patents...
A thread in the Early Color Forum got me to finally put together a list of patent "finds" that I had on an older Win Vista machine. Here's some interesting TV related patents:
Handwired Chassis: http://www.freepatentsonline.com/3337950.pdf Space Command Remote Clickers: http://www.freepatentsonline.com/2821955.pdf http://www.freepatentsonline.com/3118423.pdf Clutched Fine Tuning in Zeniths: http://www.freepatentsonline.com/3148345.pdf Duramodule patent: http://www.freepatentsonline.com/3492537.pdf System 3 patent: http://www.freepatentsonline.com/4048669.pdf The beginings of Zoom: http://www.freepatentsonline.com/2586521.pdf Zoom, matured: http://www.freepatentsonline.com/4028726.pdf 4-lead safety capacitor: http://www.freepatentsonline.com/3883779.pdf Tripler with focus divider: http://www.freepatentsonline.com/3814989.pdf How those funky yoke windings were formed: http://www.freepatentsonline.com/3086562.pdf Electrically extended car radio antenna: http://www.freepatentsonline.com/2391202.pdf Zenith Phono Cartridge and dual needle assembly: http://www.freepatentsonline.com/3582087.pdf Zenith Allegro "Mixer board" Stereo: http://www.freepatentsonline.com/D244961.pdf GE's funky slide knobs: http://www.freepatentsonline.com/3617077.pdf Motorola's Works-in-the-Drawer patent: http://www.freepatentsonline.com/3708618.pdf Motorola's innovative tripler: http://www.freepatentsonline.com/3748538.pdf RCA Mirrored Lid set: http://www.freepatentsonline.com/2207510.pdf RCA's Solid State Oscilloscope, ahead of it's time: http://www.freepatentsonline.com/4114095.pdf
Brian USN RET (Avionics / Cal) CET- Consumer Repair and Avionics ('88) "Capacitor Cosmetologist since '79" When fuses go to work, they quit! |
Neat, and I took apart a four-lead cap just a couple of days ago trying to see how it works. It was poorly installed and I have two NOS units of the same value so why not. I got photos of the mangled end of a very tightly-wound roll of foil and plastic film. I also took apart a 2-leader for comparison. I assume the narrower pair of strips is the interlock.
Hard to see details I know, so here are the full-res pics for anyone interested. https://www.flickr.com/photos/spacec...7683846157245/ https://www.flickr.com/photos/spacec...7683846157245/ Last edited by Jon A.; 05-17-2017 at 04:33 AM. |
More Space Command remotes:
The genesis: http://www.freepatentsonline.com/2821956.pdf http://www.freepatentsonline.com/3017849.pdf http://www.freepatentsonline.com/2920604.pdf http://www.freepatentsonline.com/3164127.pdf http://www.freepatentsonline.com/3327679.pdf RCA Ultrasonic Remote Clicker: http://www.freepatentsonline.com/3028830.pdf http://www.freepatentsonline.com/3165090.pdf http://www.freepatentsonline.com/3028832.pdf Motorola ultrasonic remote: http://www.freepatentsonline.com/3189000.pdf UHF Loop Antenna? A Zenith creation: http://www.freepatentsonline.com/3233240.pdf Panasonic "freeze" set: http://www.freepatentsonline.com/3908083.pdf
Tnx findm interesting stuff. Another Zenith one was the spark
gaps used in late CC2 & up. It actually worked ! We found sets hit by lightning where it was melted & blackened but the sets kept running. Only found out when the set was opened for other unrelated problems. Lightning work used to be gravy work. Only had one Admiral destroyed by a direct antenna hit. It blew a PCB to shreds. When cable TV came along it became the great destroyer of TV sets. The ground for the cable completed a circuit that common power line hits could use to send a huge surge through everything. 73 Zeno LFOD ! |
CRT Socket with Integral Spark Gap: http://www.freepatentsonline.com/4075531.pdf
http://www.freepatentsonline.com/4298815.pdf Overvoltage protection for Television Receiver: http://www.freepatentsonline.com/4375661.pdf Cable isolator with overvoltage protection: http://www.freepatentsonline.com/4575691.pdf Spark gap for line transient protection: http://www.freepatentsonline.com/4438365.pdf TELEVISION DISPLAY PANEL HAVING GAS DISCHARGE CATHODO-LUMINESCENT ELEMENTS (Plasma TV...in 1974!): http://www.freepatentsonline.com/3845241.pdf Avanti Cabinet?? : http://www.freepatentsonline.com/D229443.pdf RCA 2000??: http://www.freepatentsonline.com/D219886.pdf
Audiokarma |
Philco!
Predicta CRT case: http://www.freepatentsonline.com/D186629.pdf Funky Philco Portable: http://www.freepatentsonline.com/2872677.pdf Same Antenna, different cabinet Philco: http://www.freepatentsonline.com/2917577.pdf Safari: http://www.freepatentsonline.com/3041496.pdf And that what-were-they-thinking set: Sharp All-in-One TV/Microwave/Cassette: http://www.freepatentsonline.com/D273836.pdf
Original 6BK4A patent: http://www.freepatentsonline.com/3041494.pdf
RCA RGB-capable Flat display, circa 1962...: http://www.freepatentsonline.com/3041490.pdf Cool IBM nixie tube: http://www.freepatentsonline.com/3041491.pdf Yet another Nixie: http://www.freepatentsonline.com/2769939.pdf Double sided Nixie tube: http://www.freepatentsonline.com/2618697.pdf Siemens One-gun Color CRT: http://www.freepatentsonline.com/3041489.pdf Those really bad powerline antennas - recalled by CPSC: http://www.freepatentsonline.com/D212849.pdf Winegard's "mother of all antennas" windtrap: http://www.freepatentsonline.com/3531805.pdf JFD's metal cabinet rod antenna: http://www.freepatentsonline.com/3241149.pdf Motorola Antenna - the VT-71 makes a cameo: http://www.freepatentsonline.com/2582159.pdf
