Old 02-01-2005, 08:56 PM
stereofisher's Avatar
stereofisher stereofisher is offline
For the Love of the Music
Talking Schematic for a Zenith Transoceanic 3000
Anyone got one? Need to figure out how to get it apart. Band selector is noisy. Thanks Eric
Old 04-25-2005, 02:00 PM
Why go to the trouble of taking the set apart? A shot or two of Deoxit in the bandswitch should cure the problem. (While you're at it, a shot of the same cleaner in the volume and tone controls wouldn't be a bad idea either.) I would think you should be able to get at that switch without even pulling the chassis, unless the switch itself is hidden behind or buried under some other part of the radio. Of course, a schematic and/or service manual wouldn't be a bad thing to have. I have a service manual and schematic for my Zenith R-70 AM/FM portable on order from ManualMan.com; you can get almost any Zenith Royal series schematic from here, although you might have to wait some time for the manuals to arrive in your mail (I ordered the R-70 manual on April 15 and am still waiting).
Kind regards,
Old 05-14-2005, 08:54 PM
Ed in SoDak's Avatar
Ed in SoDak Ed in SoDak is offline
RadioHead
The bandswitch is easy to get at and spray with contact cleaner. Spray briefly then rotate fully back and forth. Be careful with it, though. It's a slightly weak design.
The shaft in the center of the switch is merely dimpled to hold it in place. Soldering the shaft to the switch mounts at a few locations will help a lot. If there's any play, the switch contacts may not be fully meshed. Rotate it slowly back and forth and see if the just the shaft turns a bit before the switch begins to rotate. If you have play, there's a problem. For now when changing bands, you can wiggle it back and forth till it settles into the right spot.
A service manual is at nostalgia Air: http://www.transoceanic.nostalgiaair.org/
-Ed
I'm so fast I have time to do it over.
