Original CRT in RCA CTC-11?
I wonder if my newly acquired CTC-11 has its original picture tube? The serial number tag on the kinescope matches the tag on the chassis.
I suppose that is a date code on the CRT base, but I can't decipher their mystical scheme. The other signs point to a low-mileage set. The cabinet is like new. Apart from replacing a couple of small tubes, the only evidence of service (if you can call it that) is where the thermistor broke into pieces and the repairman twisted its leads together to replace the inrush limiter with a short circuit. Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html |
Brian USN RET (Avionics / Cal) CET- Consumer Repair and Avionics ('88) "Capacitor Cosmetologist since '79" When fuses go to work, they quit! Last edited by Findm-Keepm; 06-16-2017 at 10:36 PM. |
My CTC10 has an original CRT also. Serial tag is on it too.
Tom Smrz |
Yes Phil, it's the original CRT. Hope it's still OK! I also have matching numbers on a CTC-11, including the cabinet, although the CRT is beyond toast LOL.
Kevin |
I would say yes. I never heard of anyone moving the serial
tag from an old CRT. Only case I would believe would be newer sets that under warranty had a strip of tags to prove you opened the set ( NAP ). With Zenith you would find matching #'s on the box, back, CRT & engraved in the chassis that you could often see through a slot. Saved my ass once when some anal orifice claimed I swapped his back for another !!! Still cant figure why I would commit such a felony. 73 Zeno |
Audiokarma |
Looks good so far. The emissions woke up quickly when I left it on the tester for a few minutes. Below is a snapshot after I had done nothing to the set except adjust some color controls and replace caps on the vertical sweep board to fix some instability.
I have done a lot of testing of resistances & voltages & waveforms to convince myself that it really is working as normally as it appears. I'm usually pretty gung-ho about replacing old electrolytics, but I'm inclined to keep my mitts out of this one, for the most part. The dilemma is that now I have a beautifully working CTC-11 in a great cabinet and no place to put it where it's convenient to watch. Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html |
I STILL do not understand the fascination with the "wizard of oz" movie--for our oldsters...NONE Of them were around to show it new.
Myself--I like a "back to the future" approach, showing something like an advertisement for some ultra-tech device or service, especially when it has a "dot com" addy showing. |
But then again...I have my 29JC20 set with a BAD 21FBP22 and it is NOT gone to air--but the red gun is pretty weak and will NOT restore...though it WILL show a fairly good result at about 7.5 volts on the fils. |
in the 1960's "the Wizard of Oz" was a once a year showing (generally) that most of us kids liked to watch. Besides the fact that the story is timeless, and Judy Garland has an incredible voice, it was one of the few color shows that really looked good on color tv. Back in the day you had to make time and plan for the big event, then all the kids on the block would watch it and report back about it the next day at school. Now a days with all the instant gratification and total lack of any planning required, and the lack of community from shared events I can understand the lack of a common show that draws so many of us "oldsters" to a single show. besides all that, the color is rich and varied so it looks good on the set, and we know how it should look, so its almost a test pattern as well. Last edited by DaveWM; 03-27-2015 at 10:38 PM. |
Phil,
The picture on that set is beautiful!! |
Audiokarma |
Phil, that is a beautiful picture. And, quite impressed that the set works so well with very little attention.
One day, one day, I will work on the CTC9 that I have. I just hope I have results that look as good! |
the correct way to see the wizard of oz is on a roundie.something about those beautiful colors in oz that came alive on a round screen set.your set looks fantastic
Just kidding ! ..... |
Great Screen Shot!
Phill......Seems RCA finally got it right with your CTC 11! It uses X Y axis 12AZ7 demods, and 6CG7 grid drivers and the 21FBP22A CRT at 24KV ultor. I was very impressed with your screen shots of Dorothy's facial graduations. Reminds me of the low level chroma demods and matrix grid amps of the CTC2B 21CT55 running 27KV ultor on a 21FBP22A. Keep posting full screen shots......Tom
Thanks, this set does make a very pleasing picture -- at least as good, if not better, than my other CTC-11s where I spent hours gnashing my teeth over convergence adjustments, etc. I have taken lots of screen snapshots in the course of (gently!) working on this TV, but none of the others are good representations.
With my cheap camera, getting a photo that resembles the true picture quality requires a lot of fiddling with ambient lighting, contrast, brightness, color level, etc. Plus, with a front safety glass, reflections are always an issue, and my new workshop has lots of big windows. Good for working, lousy for screen photography! I had to tack a black curtain over one window to take that Dorothy shot. Sometimes I think that using the Wizard of Oz is a bit of a copout. When a scene is full of bright colors, even a fairly lousy TV can look colorful (if not necessarily accurate). But the film does have a number of big close-ups, which are good for showing flesh tones. Perhaps I should go back to using Gone With the Wind. That's also a Technicolor movie but its palette is generally more subdued. Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html |
Audiokarma |
