Old 01-17-2019, 05:08 PM
goat1981 goat1981 is offline
GE 806 - Volume / Focus potentiometer help!
Hello, everyone,
I am in the process of restoring a GE 806 10" tabletop set. I'm almost done with the restoration, but the volume/focus potentiometer is bad and I need to find a replacement.
The pot is a 100k/500k dual concentric pot with a power switch. Does anyone have a spare parts chassis or pot of this type or know where I could find one?
I was able to fix the focus (100k) pot to work with carbon paint. It's not perfect, but it works. The volume pot (500k section) is too far gone, though and I am either getting full blast volume or nothing.
Thanks in advance for your help and recommendations. If more information is needed, I am glad to provide. I appreciate the help!
Old 01-17-2019, 06:45 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
You're in luck.....I have a whole front control panel for one, controls intact. PM me your address and I'll send you the volume/focus control
Old 01-17-2019, 07:30 PM
Anyone have the similar (but not identical) control for a GE 810? On the 810, the volume/power control is one unit, and a concentric hollow shaft with a pulley drives the focus pot mounted above.
Phil Nelson
Phil's Old Radios
Old 01-17-2019, 07:42 PM
This forum is awesome! PMed you, Kamakiri. I really appreciate the help.
I'll post pics when it's all done! :-)
Old 01-21-2019, 01:27 PM
Kamakiri's Avatar
Phil Nelson
Phil's Old Radios
Literally two weeks ago I did.....until a culling of my spare parts stash
Old 01-28-2019, 01:03 AM
Hello, everyone!
Tim kindly looked for this part for me, but it wasn't good. Does anyone else have any recommendations for finding this for my GE 806?
I really appreciate your help.
Old 01-28-2019, 03:06 AM
Gleb's Avatar
Gleb Gleb is offline
I hope something of that can help. The larger resistor has a 6mm/10mm shaft, the smaller has a 4mm/8mm one. I have a plenty of them on hands, and can re-assemble any one with the required resistance combination.
To understand a bygone era, you should use things from it
Old 01-28-2019, 11:40 PM
Thank you for your reply, Gleb!
The inner control is supposed to control a 500k pot for the volume and the outer control is supposed to control a 100k pot for the focus. Do you have something that would fit that description?
I'll have to measure the shafts on the originals - I doubt these would be the correct length, but maybe I could fabricate something to work.
I appreciate your help and will of course pay you for your time, the part, and shipping if you find something that can help.
Thanks again!
Old 01-29-2019, 01:34 AM
Contact Mark Oppat here:
http://www.oldradioparts.net/
Old 02-24-2019, 03:57 AM
Gleb's Avatar
Have you succeed with Mark Oppat? If not, my offer is still valid.
